I decided that this time around to just go with a fancy custom loop that not only looked cool, but kept my system cooler since I live in the desert with no air conditioning (it's a cool day at 86 F in my room right now). This build will comprise of almost all of my old build since it is still fast enough for what I need, but is really loud with the fans going full blast whenever I load up Netflix =P The only hardware I'm actually changing is my case, fans, and storage drive. The case change will give me the room I need, the fans for better air flow and looks, and the switch to a laptop drive for storage will allow me to get rid of the hdd cage and just use the 2.5" drive bays. This will be my first time building a system that uses a custom loop so I found myself having to buy things in stages; especially fittings. Right now, I'm waiting for my 3rd shipment of fittings. Luckily, nothing extra, just things I didn't see myself needing until I was putting things into the case to check the spacing. It's hard when you have a small case.
The old hardware I'm using can be found under my sig for the NZXT Vulcan build. The new hardware is:
Case: Corsair 350D
Storage: Samsung SpinPoint SATA 1Tb 2.5"
Resivoir: Monsoon S2 D5 Premium
Rads: Alphacool ST30 120mm single, ST30 120mm dual, and UT 60 120mm single
Pump: Switech MCP655-PWM
Tubing: PrimoFlex Advance LRT
Fittings: Monsoon compression, 90 degree, 45 degree, Bitspower extensions, Alphacool T and elbows, Swiftech Quick Disconnect (drain plug)
CPU Block: XPSC Raystorm
GPU Block Heatkiller GPU-X3 "Hole Edition"
Fans: Corsair SP 120 PWM
Links to Updates
8-11-13: Water Test
8-20-13: Finished Pictures
10-28-13: Lighting Updates and Backplate
12-19-13 Updates (Lighting, Drain/Fill port, Carbon Fiber Vinyl)
1-13-14 Updates (Faceplate, Reservoir Lighting, PSU Stickers)
5-25-14 Updates (Rad, GPU, Cables)
Now for the pics (I aplogize in advance for any potato pics since I only have a phone camera):
The old build:
The new stuff:
Once I began, I realized just how unmanly I was because I didn't really have any tools. So, a trip to the hardware store remedied that:
These boxes are great for organizing stuff:
I chose this style of reservoir for space purposes. Since it is a small case, the only place I could realistically fit it was in the drive bays. I had to put my blue ray drive into an external enclosure, but that's ok since I don't use it that much. I ran into a few problems trying to install the reservoir. The pic below shows my first problem. The fins in the drive bay were blocking me from being able to actually put the reservoir in, so that's where the dremmel came in handy.
The next problem I have is that the screw holes didn't line up exactly, so the reservoir doesn't sit flush with the case. I could expand the holes, but I'm actually using the vibration dampener screws so they don't tighten up well enough to hold it in place if the holes were to be expanded.
If you noticed in that last picture, there was a big hole in the top of the case. That's for the fillport. Once I have everything installed, I won't be able to get to the reservoir to fill it without having to take apart some of the tubing, so here's the fillport installed:
Now, here's a pic with the pump cables sleeved and installed. One thing I like about the reservoir is the detail they went into with not only looks, but silencing; as you can see by how the pump is fully covered.
So, here's where I'm currently at. I have some last few fitting that are coming in sometime next week. This weekend I plan on getting what I can installed and ready to go for when I get the fittings in. I'm going to install everything I can before I put in the hardware since I am transferring hardware, I want to do it with the least amount of downtime. There is enough room for me to maneuver my mobo into place with the rads installed. I will do a leak test today of the parts, hopefully none of them leak.
Case: Corsair 350D
Links to Updates
8-11-13: Water Test
The old build:
The new stuff:
