This would be my first try at building a case or maybe desk modding? Been looking at some of the builds and figured it was about time i tried a build myself.
The plan is to mod the existing Z-Line Designs Delano L-Desk or at least part of it. So my first try is gonna be the wife computer which is basically 1/2 the desk. hehe.
Mostly existing parts, with recently added water cooling. Originally in a Coolermaster HAF922 Case.
Existing Parts:
Rampage II Extreme
I7 980X
Corsair 950w
XFX 7970 (Non Ref)
OCZ Vertex 80GB
WD Green 2TB
Noctua NF-P12
Noctua NF-A14
XSPC Raystorm CPU Block
XSPC AX240
EK XTC140
XSPC Dual Bay Reservoir
Swiftech MCP655
XSPC Raystorm GPU block
Enzotech Heatsink
New parts:
Bitfenix recon
Noctura NF-R8
Corsair SP120
RGB Strip lighting with wireless remote
Logisys CLK12UV2 Dual UV Cold Cathode Kit 12IN 3.0MM
Monsoon Hardline Tubes (Clear)
Monsoon Hardline Fittings
Bitspower D5 pump top
Apex SK-393-C Mid Tower ATX Case
Everything was planned and drawn to scale on Google Sketch. Ver1 was a little big and the chair arm rest wouldn't be able to slide under. Ver2 was modded to allow a bit more leg room. Decided to build on Ver3, figured only need 1 duel bay.
Built with scrap plywood i had laying around. Would of loved to make this out of sheet metal but neither have the skills or the tools to do so.
Smooth out the wood so to hide imperfections in the wood.
It was cheaper to buy a case and take it apart than to buy a motherboard tray.
Mounted on the Legs
Molded the fan controller into the front.
Clear Uv Spray
Some RGB Lighting
Well, that's it for now... Its pretty much at a full stop for a week or so since when i bought my acrylic tubes and bending kit, they forgot to pack the silicone tube.
Let me know what you guys think. What improvements can I make? This is only the first build, there will be another one coming after this one is completed (My desk, lol)
Existing Parts:
Rampage II Extreme
I7 980X
Corsair 950w
XFX 7970 (Non Ref)
OCZ Vertex 80GB
WD Green 2TB
Noctua NF-P12
Noctua NF-A14
XSPC AX240
EK XTC140
Swiftech MCP655
Enzotech Heatsink
New parts:
Bitfenix recon
Noctura NF-R8
Corsair SP120
Mounted on the Legs
Clear Uv Spray
Some RGB Lighting
