Welcome to the EK-Posure build log!
I've jumped back and forth between ITX and ATX builds over the past couple of years and it's about that time to switch things up again. I've always had an interest in tackling a water cooled test bench build, so when Microcenter had a random Lian Li PC-T60 test bench sitting on the shelves I took it as a sign. As this is the first build log I'll be publishing, I'm not sure what should be expected for content/updates, but I'll post as much as I can to keep everyone in the loop as to what's going on. Thanks for stopping by!
Case: Lian Li PC-T60 Test Bench
CPU: Intel i7-5820k
Mobo: MSI X99A SLI Plus
RAM: G.Skill Value 32GB (4 x 8GB) 2400mHz DDR4
GPU: EVGA GTX 980 ti SC
PSU: Corsair AX760i
SSD: Crucial M4 256 GB
SSD: Crucial M4 128 GB
HDD: Western Digital Caviar Black 1.5TB
Fan Controller: TBD
Cooling Components
CPU: EK-Supremacy EVO X99 - Nickel
GPU: EK Thermosphere Nickel/Plexi Updated
Pump: EK-XTOP Revo D5 - Plexi
Reservoir: EK-RES X3 150
Radiator: Watercool MO-RA3 9x140 Pro
Fans: Noiseblocker BlackNoise PK-3 x 9
Fittings: EK-ACF 10/13mm Compression Fittings - Nickel
This is basically the final list for components that I'll be using in this build. As always, this is subject to change, but seeing as I'm only freelancing at the moment the budget won't allow much deviation. I have everything in my possession currently, so it's just a matter of modding and completing the build. Easy, right?
