euphoria : air540 haswell build : :
hello ocn!
presenting euphoria! a sexy watercooling air540!
(SCROLL THROUGH ALL OF PAGE1 OR THE GALLERY TO SEE BUILD IMAGES, FINAL ONES AT THE BOTTOM UNTIL I GET A BETTER CAMERA)
hardware : current/done : :
Always looking for suggestions or ideas! Let me know,
Now some pictures of the current case: (sorry for the pictures from my galaxy s4, neither me or my lady own a digital camera surprisingly)
new case arrives / aftermath of build: : (last case was a HAF XB)
looks like fedex rolled this thing in the dirt. was nice and secured on the inside, first thing i noticed was the large bag the case was in? construction quality is nice, everything fits well and i can see alot of possibilities for modding on this case, although there probably won't be much on this first build.
one thing i wasn't aware of was that the side window was tinted, i dont like it much with normal lighting. however with some light strips in there it will probably be a benefit.
hmm
for some reason ocn rotated these pictures? oh well im too lazy right now to fix it, you get the idea.
closeup of the hyperx ram and h100i
sideshot, hdd's will be mounted on the other side of case once finished with WC loop.
try this cameraphone with some flash!
side/angle shots without the covers off!
first conclusion of case: nice easy case to work with, decent quality, visually appealing, i didn't experience any better temperature from the airflow design. (i came from a haf xb which i believe had better airflow around the gpu/rad on the top compartment, however this one is close there with it) case is a must have! different from the norm, and fun! has my recommendation.
hello ocn!
- Corsair Carbide Series Air 540 High-Airflow
- Intel Haswell 4770k
- Asus Sabertooth z87
- 2x Nvidia GTX770 SC ACX
- Kingston HyperX Beast 2400 cl11
- Samsung 120GB SSD
- WD Blue 1tb
- Corsair hx850 psu
- 5x Corsair SP120 High Performance
- 1x AF140 Quiet Edition
- EK Supremacy Acetal+Nickel CPU Block
- EK Geforce GTX 770 Acetal+Nickel GPU Block x 2
- EK Terminal Block Black Acetal
- EK Reservoir + pump top + D5-Vario Pump Combo
- Black Ice GTX Xtreme 360 Radiator
- Black Ice GTX Xtreme 240 Radiator
- Alphacool 3/8" x 5/8" compression fittings
- PrimoChill PrimoFlex Advanced LRT tubing (3/8x5/8)
- Mayhems Pastel White coolant
- nzxt sleeved bright led kit
- Sleeving (white)
- new sli cable (orange is ugly)
hmm
