Hi guys, I decided to share my build log with you and get some help as much as possible . I have already bought a few parts with has been marked as a "purchased".
List of parts:
CPU: Intel Core i5 3570K - purchased
Mobo: Gigabyte GA-Z77X-D3H - purchased
GPU: MSI HD 7950 Twin Frozr III - purchased
HDD: 1TB WD Caviar Blue - purchased
SSD: 120GB Samsung 840 PRO - purchased
Case: Corsair Carbide Series 500R - purchased
CPU Fan: True Spirit 140mm - purchased
DVD±RW: LG GH24NS95 24x DVD Writer - purchased
RAM: Corsair Vengeance Jet Black 8GB DDR3 1600 MHz - purchased
PSU: 650W Corsair Enthusiast Series TX650M - purchased
LCD: Philips 239C4QHSB 23" IPS - purchased
Now the worst part of my build log, questions
Is there anything I should know before I'll install Windows ?? Any special settings in BIOS for stable performance and SSD ??
Do I need any of the mobo software like "EZ Smart Response" "GIGABYTE EZ" ??
Im gonna order CPU this friday (probably) and I dont know if I should give it a try with this :> Should I ?
Which thermal paste would you recommend, Zalman ZM-STG2 or Arctic Cooling MX-2 ??
What do you think about this - link ? Basically to get more airflow space and remove HDD cages but I dont know if is necessary to have a cooler for HDD/SSD so I'll wait for your opinion or maybe any way to install some cooler on the back of 5.25 :>
Which additional fans would you recommend ? The one included with the case are good enough or should I replace them as well ?
For that many fans I need some fan controller so I was thinking about this one. Do I need 3-pin splitter for all my intakes fans ? As far as I know there is only 3 places on my mobo for fans.
Is it good solution for airflow - http://img560.imageshack.us/img560/2814/sdfsfd.png ??
PS: Sorry for my english, Im still working on my grammar
Thanks in advance
List of parts:
Thanks in advance
