1 - 20 of 25 Posts
This is my second build and first WC build.
:D
Hope you enjoy the pictures
(give me some time to upload them)
Here are the SPECS and stuff:
Main Components:
Motherboard: Asus Sabertooth Z77
CPU: Intel core i7 3770k ivy bridge
GPU: EVGA GTX 680 2680KR 2GB
RAM: Kingston Hyper x1 black series 8GB DDR3 1600
SSD: Corsair Force Series 3- 90 GB *2 (raid 0)
HDD: Western Digital VelociRaptor 300GB sata II
DVD: Samsung CD/DVD Burner Model SH-222AB
Power Supply: Corsair professional series AX850
Case: NZXT switch 810 Matte Special Edition
Water Cooling:
Waterblock CPU: EK supreme HF universal cpu cooling block- Copper/plexi
Waterblock GPU: EK geforce FC680 copper plexi
Pump: Swiftech mcp655 with speed control
Reservoir: EK Dual Bay Spin Reservoir
Reservoir: EK multiOption Res X2- 100 Basic
Radiator: XSPC RX360 triple 120mm radiator rev2
Fan control: Scythe Kaze Master Pro controller- KM04-BK
Coolant: Mayhems Aurora Nebula Blue
Tubing: PrimoChill primoflex pro ½" ID 3/8"OD clear- 10 ft
Compression Fitting: Monsoon Compression fittings ½"- six pack-blue
Fan: Gelid Wing 12 PL blue 120mm *12
Acessories:
Backplate: EVGA GTX 680 backplate
Wire extension: Bitfenix alchemy multisleeve 24 pin extension cable- blue
Wire extension: Bitfenix alchemy multisleeve 6 pin PCI extension- blue x2
Wire extension: Bitfenix alchemy multisleeve 8 pin PCI extension- blue
Pump custom: Bitspower D5/ MCP655 pump mod top acrylic black
Pump custom: Bitspower D5 Pump Mod Kit- blue
Lighting: NZXT sleeved LED case Light kit 2Meters- White
Peripherals:
Monitor: ViewSonic VX2450wm- LED 24" monitor *2 (Dual)
Keyboard: Razer Black Widow Ultimate Stealth Edition
Mouse: Razer Mamba 2012
Mouse pad: Razer Ironclad mousepad
Headset: Razer Tiamat 7.1 headset
Speakers: Logitech Z-2300 2.1 speakers
Webcam: Logitech C920 Webcam
Discussion Starter · #2 ·
Click the links to see all the pictures. Hope you enjoy them
Switch 810 case
450
450700
No cut outs, but it's alright
450
RX360
450
Spin Res
450
150 Res
450
GPU waterblock
450
CPU waterblock
450
655 pump mod
450
655 pump
450
Gelid fans
450
450
Monsoon fittings
450
Fan controller
450
CPU 3770k
450
Ram
450
450
GTX 680
450
AX850
450
Just to see if components are working properly
450
450
450
450450
450
450
back plate not compatible, but zip ties fix everything right?
450
450
450
450
450450
450
450
450
450
450
450
Why the pump is mounted so high? waiting for a kind person to donate a EX240 rad
450
Doing the "fill and pray" test
450
450
450
450
450
450
450
450
NOTE: color is a bit off, it's not purple, it's blue, (i hate my camera)
450
450
450
Tried my best... stupid cables...
450
450
450
450
450
450
Reserve
Wow that looks really good, that's the exact same pump, top, and mod kit I used, great minds think alike huh
I saw you asked about adding an RX240 to your build in the Switch thread, and wondering if it will change temps? I think it would...you said load temps are around 70 Celsius, that's kind of high and you probably could be doing better.
EDIT: Just looking through the pics closer, any particular reason for using two reservoirs?
Discussion Starter · #9 ·
Originally, I wanted to see the awesome effect of the mayhem aurora coolant, but since that coolant didnt last long, I might take that 150 res away and just use the bay res.
Is adding 240 radiator a good idea? I mean, would you do it?
Not only would I, I did
Check my build log, RX360 and an EK 240 went into my Switch.
EDIT: Just to save you some time digging through the log
700
Wow, I can't believe this doesn't have more views. You did a fantastic job!
^this
You did an amazing job! Very clean build for sure. Think I might steal a few ideas for my upcoming build
Discussion Starter · #13 ·
700
This is so awesome!!
but I heard that you need to drill holes to mount a 240 on the front. I might just put it at the bottom.
awesome build!
Drilled holes. Mounted it with the included screws
Left enough space for a EX 240 rad in the bottom for the future
Oh... it looks like your using some kind of stand under it that is mounted.
I'm curious what extra stand your using.
awesome build!
Thank you
Yea you do need to drill holes in the front to mount a 240...so yea bottom is always good, it was meant for it.
4.5 ghz at 1.25 V
1.23V failed after 5 hrs. So I increased the voltage to 1.25.
Nice i have the 3570k at 4ghz with 1.12v on air. Water cooling soon so i will set around the same voltage and hope i get some good results. How quiet are those fans? I want to get the same gelid wings.
1 - 20 of 25 Posts
