1 - 20 of 22 Posts
Hi
So i've started off browsing the forums and came across a totally new understanding for PC cooling. I know the importance since i Love to Overclock for that extra Frame or Few whilst gaming. It's because of each one of YOU that i'm soo often on here checking people's watercooled pc's . . ( s0o0o WOW!!!
), tech updates, everything pc related really that got me to come and join. This build is for cooling Mostly and to gain higher overclocks and BETTER temps.
Current Build:
2500k OC to 4.8Ghz
Asus Z68 V/Pro Gen3
Western Digital caviar Black 1TB
64Gb Vertex 3 ( Used to cache my 1TB , Speeds are Really nice and im always in games before my buddies)
2 X 4Gb G Skill Sniper Gaming Ram , Low Volts
H100 ( 4fans push/pull config)
GTX680 Lightning ( What a Beast of a card! )
Cooler Master Silent Pro GOLD 1000watt PSU
Here are the goodies that arrived recently and my gpu which i done. My Motherboard was sent to suppliers and should only be able to continue Build in a week or 2 for latest i hope.
Watercooling Goods:
XSPC Raystorm CPU Waterblock - Intel
Swiftech MCP655™ Series 12 VDC Water Pumps - With Speed Control
2 X Monsoon Free Center Compression Fittings, 1/2" x 3/4" Six Pack - Red
2 X Monsoon 45° Rotary Angle Fitting - 3/4" - Red
2 X Bitspower Single Luxury Tube Clamp LTC7 For Tube OD 3/4in. - Red
Alphacool NexXxoS XT45 Full Copper 360mm
Koolance RP-452X2 Dual 5.25in Reservoir for 1-2 PMP-450/S Pumps, Rev.2.0
EK-FC680 GTX Lightning - Acetal + Nickel
PrimoFlex Advanced LRT Tubing - 1/2in. ID X 3/4in. OD - Bloodshed Red
Bitspower Premium G1/4" "Stubby" High Flow 1/2" Fitting - Deep Blood Red
Bitspower Deep Blood Red "T" Fitting - 180 Degree Water Cooling Accessory
Bitspower Sealing Plug - 1/2" - Deep Blood Red Finish
Koolance Radiator Mounting Bracket with Quick-Release
Alphacool NexXxoS Monsta 480 Radiator
NEW *** Xigmatek XAF-F1254 120mm Copper Brushing Axis Fan - Black Blade, White LED
2 X Koolance Dual Ultra Bright LED Cable - 3mm, 4-pin - Blue
2 X Koolance Dual Ultra Bright LED Cable - 3mm, 4-pin - Red
Gelid Solutions GC EXTREME Thermal Compound - 10G
Lights i will use in block and Res
Update: Done my Loop. Wow my First Time and Boy was putting those Compression Fittings on a Job! My hand was sore for 2days. The pipe makes a easy nice tight fit on barb but screwing the fitting closed in the threads is a MISSION!!! I sorta scraped some of the red colour doing a old trick well known as "Force".
To come. .
LED Strip X2 to cover below casing since casing is on wheels and UV Cathode to make tubing POP. Waiting on Fan aswell to put on inside rad. Thanks For keeping intune. Will post better pics when final stuff comes through. I am impressed with temperatures and WOW!! The temps with GPU under water is amazing!
Discussion Starter · #6 ·
I've got silver bullet in a 3way fitting in bottom for Drain. Had no space in res for bullet and wanted a drain to make changing liquid easy. But really the tubing thickness is Hard to work with and the bends without angled fittings i know looks messy but will have to do for now. I might get another pump to run in serial and add few angled fittings for a cleaner loop soon
More angles equals more restrictions and i'm after performance
Got LED's in and UV cathode.
2X BitFenix Alchemy Connect™ 30 LED Light Strip - 600mm - White
1X Logisys 15" Deluxe Sound Activate Cold Cathode Kit - UV
And some cabling.
Here are some pictures
Ok, my drain which uses a Bitspower tube clamp came off , but that was when hose was flipped upwards from gpu out. Got a huge Fright! But luckly i lifted it up quick enough.Only drips came out because tubing slipped off. I had 1 more compression fitting left and replaced the one clamp where leak came from. Would really want to replace the other clamp since those clamps are too small to go over the tube which is also on a barb fitting. That specific Clamp is Only enough to go over tube and tighten. Feels Risky to me but that joint is sealed for now aswell as the other one with the clamp.
Question:
Does UV Cathodes take time to Burn in?
I placed mine in but it seems Very Dim. Here is link to the One i have:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=72_277&products_id=3322
And i've added the following White led strip below case:
http://www.frozencpu.com/products/12827/lit-246/BitFenix_Alchemy_Connect_30_LED_Light_Strip_-_600mm_-_White_BFA-ACL-60WK30-RP.html?id=gar2QUy6&mv_pc=775
Sorry about picture quality. I'm always in a hurry to take snaps and move along.
Update Time
Got following and added:
1 x Monsoon Free Center Compression Fittings, 1/2" x 3/4" Six Pack - Red
2 x Bitspower BP-DBRWP-C73 Deep Blood Red Dual IG1/4" Extender - 25MM
1 x 15'' Cold Cathode Add-on Tube Sleeved - Ultraviolet
1 x Bitspower Deep Blood Red Rotary Fitting "Q" PLUS - 360 Degree Water Cooling Accessory
1 x *** NEW *** EK-FC Bridge SINGLE - Acetal
1 x Phobya Temperature Sensor/External thread G1/4 with C/F Display
1 x Phobya Temperature Sensor In / Outer Thread G1/4
1 x Phobya Front Faceplate - 2 Displays - Black
5 x *** NEW *** PrimoFlex Advanced LRT Tubing - 1/2in. ID X 3/4in. OD - Bloodshed Red
3 x Alphacool Ultra Pure Water 1000ml
1 x Bitspower BP-MVV-BK Mini-Valve - Black Sparkle
1 x PPCS SuperStrong Thermal Tape ( for Temp Probes ) - Translucent Double-sided
1 x Thermometer With Digital Display - C/F Display
I'd be a bit worried about those tiny (poorly made as well) fan screws holding onto that large of a radiator. As you can see, it is already bending under the load. That rad probably weighs ~10lbs full of water. I have a set of the alphacool copper plated screws and would not trust them to hold that. I'd at least go to a hardware store and get grade 5 or 8 hardware. However, the threads on the rad really aren't rated to hold that load either, so you may want to think about revising your fitment of the rad.
Discussion Starter · #12 ·
Thanks for making me aware. Can you recommend any from PPC's or Frozen CPU to serve the purpuse and what sizing and threading should it be if i may ask? i would not know what to ask and what would fit into the screw threads of the Rad
Just take the screws to your local hardware store like Ace Hardware, True Value, DIY, etc. They'll help you find some. You can make sure it will work by trying a nut of the same size. Make sure that nut threads onto both your screw and the screw you are buying. You won't find grade 8 in that size, but you should find something quite a bit stronger than those cheapo ones that come with the rad. They sometimes have stainless
As long as you like what it looks like and keeps the components cool who really cares what others think of the looks. IMO it looks fantastic I'm going to do something similar to my second rig. Its not like your entering a case mod contest you built something with what you had. Instead of cutting the crap out of the structural integrity of the case. I personally like the rad outside the case. Hope you get the mounting completely sound!
Discussion Starter · #20 ·
Haven't been here in a while. Firstly thanks for the nice comment
Much appreciated!
This is my first WC build and it's definitely according to how i had visioned it
I have definitely learned a few things since having finally built a loop myself, aswel as seeing everyone else's, after all it is here where i got the inspiration to do a Custom WC build coming from just a H100.
Few changes i have made since then was getting
A dedicated sound card , The ASUS STX and
I tried SLI with a ref GTX680 to see how performance was and to experience SLI for myself.
I then sold the reference Ref GTX680, and the Waterblock for the Lightning 680, Slapped the stock Lightning cooler back on and boxed it to make way for my new GPU, Being the EVGA GTX780SC.
Plans i got coming up:
Once the Lightning GTX780 comes out i plan on getting 1 for myself, the actual goal is to sell my GTX780, get 2 Lightnings 780's and slap waterblocks on them and call it a day
1 - 20 of 22 Posts
