Hi everyone! This will be my first build log, so bear with my while we go through with this! I assure you that you won't be disappointed
As of right now, this is what I have:
Parts:
CPU: i7 2600k
Mobo: ASRock Z68 Extreme3 Gen3
Memory: G. Skill Ripjaws X 32GB 1600Mhz DDR3
SSD (OS): OCZ Vertex 4 128GB
SSD (Games): Intel 320 Series 80GB
SSD: (Games 2): Intel X25-M 160GB
HDD (Storage): Seagate Barracuda Green 5900rpm 2TB
GPU: EVGA GTX 670 FTW
PSU: Corsair TX650M 650w
Case: NZXT Phantom (originally black)
And then a bunch of other small things like keyboard, mouse, monitors, add-on cards, etc.
Water Cooling:
Radiator: EK CoolStream 360 XTX
CPU Block: EK Supreme HF - Gold Plated
GPU Block: Heatkiller GPU-X³ GTX 680 LT
Pumps: Koolance PMP-450 (x2) [Will only be utilizing one for now]
Res: Phobya Balancer 150 - Gold Plated
Pump Top: EK-D5 Dual TOP 2-LOOPS
Compression Fittings: Phobya 1/2" OD 3/4" ID - Gold Plated
Tubing: Primochill Advanced LRT - Onyx Black
And then the usual accessories like angle fittings, kill coil, etc. Coolant will be good 'ol distilled water!
Table of Contents
Update #1: Some old pics + current state of build
Update #2: I'm alive!
Update #3: Block mounting
Update #4: Test fitting
Update #5: Leak testing
Update #7: Final pics + lighting
Parts:
CPU: i7 2600k
Water Cooling:
Table of Contents
