[Current State]
- Planning Phase I -- [minor update]
- Cables and Fan Controller -- [minor update]
- Second 2007fp aquired -- [PLP achievement unlocked]
- Moved, Settled in, minor build update
- Fittings and pipe teaser
- 8-Slot I/O Panel Arrived
- Stainless over copper, sand and polish!
- Progress on Front Faceplate
- Rough cut outs for a few panels
- Large bay panel fitted, work in progress
- TJ07 Silliness
- Mid-Plate and second 5.25" Plate Fitted
- Rad Mount Blanks
- Delay in Build...
Trip to the ER
- Roughly what my desk will look
- Making a new mobo tray and made cover for fan controller
- Switched RAM...G.Skill to Dominator Platinum
- Rear panels mounted
- Test mount I/O Panel
- I/O Panel Mounted to Rear Panel
- Mobo Tray Attached and first look at Rad Mounts
- Playing with some copper tubing
- Fan Controller Cover fitted
- Put together
- Pump, Rads, Mounts, Mouse, Keyboard...oh my.
- I/O Opening
- PSU Mount and new Front Rad Mount
- Parts and painted fittings
- Mounts fitted to case
- Rad Flush
- Some Parts Together and Ran into Road Block
- Roadblock wasn't a roadblock, I was just an idiot
- More tubing bent
- More case mods and midplate work
- Bottom compartment tube bending
- More bottom compartment work
- I made another idiot move
- Thoughts on hard tubing and various fittings
- Giant desk
- Clean waterblock, bulkhead fitting, and preview to custom doors
- D5 pump died...ordered PMP-500 as replacement
- Desk cut out
- Another trip to the ER
- New 670 FTW vs old 670 FTW
- Hard Drive Mounting
- Desk Painted and made custom mouse pad
- No joy on universal GPU blocks...ordered full cover blocks
- Full cover GPU blocks installed
- New pump plumbed
- It's a Boy!!!!
- Monitors on desk and wired up
- Shot of fittings before paint and initial lower chamber leak test
- Making tubes
- It fits...well, yeah...
- Loop, but ordered fittings to redo
- Fittings arrived. Went parallel
- With RAM and mobo leak test
- Full loop together, begin leak test, find leak
- Continued leak testing
- Ghetto Cable Setup
- As she all sits
- More as she sits
- Photoshopped designs
- Speakers Arrived
- Found PLP Wallpapers
- Parts removed from TJ07 and moved to spare case
- Testing White LEDs
- Fitting the doors
- More LED Testing
- Some work done thus far
- Windows and Vents Cut
- Filing for symmetry
- Doors mounted
- Vent Choice and Powder Coat Options.
- Doors Mounted with Countersunk Screws
- Couple Vents Rough Cut
- Vent Flush Fit
- Top Vent Fitted
- All Vents Fitted and Sound Card
- Plexi Cut for Window
- Window Inlayed
- All the pieces together
- Things to get welded
- Most of the Copper Tubing Painted
- OT: Upgrade for the Parents (Happy Mother's Day)
- Updated the PSU
- OT: I took some things from derickwm
- New Hard Drive mounting
- AX1200i Cables done
- Interior Pieces Assembled
- Everything Assembled, Off to the Powder Coater!!!
- Corsair AX1200i Pinout
- Random fun: Playing with derickwm's audio gear
- Custom SLI Bridge now in the works
- SLI Bridge Shaped
- 1 vs 2 LEDs in the GPU blocks
- Back from the Powder Coater!
- Test Fitting the Powder Coated pieces, part 1
- Test Fitting the Powder Coated pieces, part 2
- Testing with parts inside
- Getting ready for water!
- Cleaned the blocks, individually leak testing
- More Leak testing...
- Just little bubbles left
- Fan controller on the fritz
- Fan controller fixed?!
- Moved to it's resting place
- Doors on...but fan controller isn't fixed
- Temporary fix
- Prettier pictures...so pretty you can see all the imperfections
