Hi Everybody, my first post here.
The Prodigy is here!
I've been planning something like this for a while but until recently there hasn't been a decent high-end ITX motherboard or a case that's liquid cooling friendly. Some components will be reused (taken from another system) like the PSU, GPU, and Silverstone 180mm fan.
I'm not planning to put a block on the 7850 because 1) it doesn't get that hot even when overclocked 2) the stock fans are very quiet 3) haven't seen a full coverage block for 7850's.
I will update with more pics as I go along. Here's what I have so far:
PICTURE GALLERY
SYSTEM
CASE
Bitfenix Prodigy White
http://www.ncix.com/products/index.php?sku=71144
Intel Core i5 3570K
http://www.ncix.com/products/index.php?sku=70541
MB
ASUS P8Z77-I Deluxe
http://www.ncix.com/products/index.php?sku=71116
G.SKILL Ripjaws X F3-12800CL7D-8GBXM 8GB 2X4GB DDR3-1600 CL7-8-8-24
http://www.ncix.com/products/index.php?sku=70119
PSU
Corsair HX650
http://www.ncix.com/products/?sku=42532&vpn=CMPSU-650HX&manufacture=Corsair
FANS
3 x Zalman ZM-SF3 120mm White (radiator)
http://www.zalman.com/eng/product/Product_Read.asp?idx=406
1 x Bitfenix Spectre 140mm White (rear exhaust)
http://www.ncix.com/products/index.php?sku=64848
FAN CONRTOLLER
Bitfenix Recon Touch Screen
http://www.ncix.com/products/?sku=71195&promoid=0
GRAPHICS
Sapphire Radeon HD 7850 OC
http://www.ncix.com/products/?sku=69913&vpn=11200-01-20G&manufacture=SAPPHIRE
SSD
Crucial M4 128GB
http://www.ncix.com/products/?sku=74849&vpn=CT128M4SSD1&manufacture=CRUCIAL%20TECHNOLOGY
WATERCOOLING
RADIATOR
XSPC EX240
http://www.xs-pc.com/products/radiators/ex-series-radiators/ex240-dual-fan-radiator/
RESERVOIR
Swiftech MCRES-MICRO REV2
http://www.ncix.com/products/?sku=34401&vpn=MCRES-Micro%20Rev2&manufacture=Swiftech
PUMP
Swiftech MCP-355 (aka Laing DDC)
Aquacomputer Aquacover Top
CPU BLOCK
Swiftech APOGEE HD
http://www.ncix.com/products/?sku=65366&vpn=Apogee-HD-WT&manufacture=Swiftech
FITTINGS
8 x Monsoon ID 3/8" OD 5/8" Compression Fittings Matte Black
1 x Bitspower Coolant Temperature Probe Matte Black
1 x Bitspower Clear Stop Fitting w/ 5mm White LED
2 x Bitspower 45 Degree Matte Black
1 x Bitspower 15mm Extension Matte Black
1 x Bitspower 30 Degree Matte Black Adapter
1 x Bitspower 60 De4gree Matte Black Adapter
2 x Bitspower 90 Degree Matt Black Adapter
2 x Bitspower 8mm Extension Matte Black
TUBING
Primochill Primoflex Pro LRT White 3/8IN ID 5/8IN OD
http://www.ncix.com/products/?sku=41663&vpn=PFLEXP10-58-W&manufacture=Primochill
COOLANT/BIOCIDE
Distilled Water
Silver Kill Coil
PICTURE GALLERY
SYSTEM
CASE
Intel Core i5 3570K
MB
ASUS P8Z77-I Deluxe
PSU
Corsair HX650
FANS
FAN CONRTOLLER
GRAPHICS
SSD
Crucial M4 128GB
WATERCOOLING
RADIATOR
XSPC EX240
RESERVOIR
PUMP
CPU BLOCK
Swiftech APOGEE HD
FITTINGS
TUBING
COOLANT/BIOCIDE
Distilled Water
Silver Kill Coil
