1 - 20 of 56 Posts
Hey guys so, i'm back from a 3 year hibernation
if some of you can remember my last build dubbed "The Scarlet" your awesome!
if not, look it up
anyway, so i finally had some free time from being deployed/stationed left and right so i decided
to come back to my old hobby, which isssss WATERCOOLING!
:D:D
so i'm putting all the stuff below to a white corsair 600T... more updates later when i get home!
finished product:
· 2 Easy
Looking really good so far I look foward to seeing more.
Looking really sweet. I also have the same case and been wondering all along to watercool it.Subbed! Just 1 question though. How did you fix the res into the case? I don't have any tools except from a screwdriver so drilling is out of the question.
That power....
Okay time to stalk here..
Subbed. I like the color scheme so far, and I like the layout you have going. Interested to see what this looks like when its done. subbed.
· back at it
dat ram. dat PSU. dat sleeving. dat dat dat BUILD!!!! so subbed. also you should update your sigrig
Discussion Starter · #16 ·
for the longest time i wanted to update it but i can't seem to figure out how since i haven't been around here and just barely coming back, anyone care to point it out for me
· back at it
1-its dayum lol
2- go to your profile, scroll to the bottom and you should see your rig. bring the cursor over, then an edit button appears. then you can figure it out
Discussion Starter · #20 ·
1-its dayum lol
its more of deymmmm than dayuuummm
-- thanks!
Originally Posted by d33r View Post
nice build, those are some cool heat spreaders on your ram modules!
thanks, im also planning to powdercoat them white
1 - 20 of 56 Posts
