Main Components:
Case: Cooler Master MasterCase Pro 5
CPU: Intel I7 6700K
Motherboard: Gigabyte Z170x Gaming 6
RAM: G.SKILL Ripjaws V Series 16GB (4GB x 4) DDR4 3000
GPU: XFX R9 290X 8GB (x2)
SSD: SAMSUNG 850 EVO 250GB
HDD: Seagate Barracuda 2TB 7200 RPM 64MB Cache
PSU: Cooler Master V1000
Fans: Cooler Master JetFlo 120 Red (x6)
OS: Windows 10 Home
Water Cooling:
CPU Water Block: EK-Supremacy EVO - Nickel/Acetal
GPU Water Block: EK-FC R9-290X - Acetal (Rev.2.0) (x2)
GPU Backplate: EK-FC R9-290X- Black (x2)
Pump/Reservoir: EK-XRES 140 Revo D5 PWM
Pump Bracket: EK-UNI Pump Bracket (120mm FAN)
Radiator:: Alphacool ST30 360mm Radiator
Radiator:: Alphacool ST30 240mm Radiator
Radiator:: Alphacool ST30 120mm Radiator
EK Terminal: - EK-FC Terminal DUAL Parallel 3-Slot - Acetal
Fittings: - Alphacool 3/8 x 1/2 Compression Fitting - Deep Black
Tubing: - Primochill PrimoFlex Advanced LRT 3/8in. ID X 1/2in. OD - Bloodshed Red
Drain: EK-AF Ball Valve (10mm) G1/4 - Matte Black
Wire Management:
CableMod CM-Series VS Cable Kit - Red
CableMod Cable Combs - Black
Phobya 4pin PWM Extension 30cm - Black (x2)
Phobya 4pin PWM Extension 60cm - Black (x2 x1 )
GELID 350mm PWM Y Cable - Black (x2)
Startech 12" round SATA Cable (x2)
Lighting:
CableMod WideBeam Magnetic LED Strip White - 30cm
Original Components:
CPU: Intel Core i7-5820K
Motherboard: MSI X99A SLI Plus
CPU: Intel I7 6700K
OS: Windows 10 Home
Water Cooling:
Wire Management:
Lighting:
