Well starting off, I had two defective MSI X99 boards in a row but everything went smoothly after switching to Z170 chipset. So I would say that I wish i would have just started with a Z170
Ordering fittings was kind of a pain. You can draw up your loop on paper but you wont really know if it will work or not (or look right) until you start installing everything in your case. So instead of a 90 going here i needed a 45 or vice versa .
Aside from that everything went together pretty smoothy.
Hello Rysydrome,Originally Posted by rysyndrome
Hi Lucky23, love the build...I just purchased a MasterCase Maker 5 and I am planning to SLI 1080's in it watercooled like you. Is there anything you wish you had done differently or improvements you plan to make to your build? This will be my first custom watercooling build. Appreciate any feedback you care to give.
