UPDATE : Change somethings have a new board, GPU's and external radiator.
Finished Photos
[Orignal Post]
[Orignal Post]
[Orignal Post]
[Orignal Post]
Well this is my first loop and my first build log. Currently I have a 700D with some air cooling. I finaly got little extra cash to play with some watercooling. So this is my build log.
Here is some before shots.
Today I did some simple painting to my DVD drives I know its been done plenty of times but first time I worked with painting I had fun with it here is how it looked.
This is a before shot of the metal sanded down
Here is what it looked like after sprayed when drying.
I also painted the tops of the screws so they wouldn't stand out to much.
I had to paint a small section of plastic I move the SATA intreface's PCB back into the casing and taped it off really good. Removing the SATA PCB on both drives was really easy.
Here is two shots of finished product. Should look much better in the case with the white tubing I will be using.
I received the 360 RAD from another Used from another user on OCN. I was pretty upset when he used clear package tape directly on the Rad to pack it. I been waiting for days now for a reply and some type of compensation. What would you do if this happen to you ? When it was sold to me pictures where in perfect condition. Now ill have to repaint it. My next two thing to do list for this is cut a 240 Rad hole in the bottom of the case and paint this messed up rad.
Here are some pictures of the rad.
Paint on the tape
here are my parts list :
1x Liang D5 Vario Pump
1x Swiftech GTZ CPU water block
1x XSPC RX360 rad
1x XSPC RX240 rad
1x EK GeForce 570 Block - Nickel
1x EK GeForce 570 Block - Nickel (Used)
1x EK FC Bridge Dual Serial
2x EK FC Links
1x Bitspower 3.5in. Bay Res - Black Acetal
3x EK Replacement Liquid Block Thermal Pads
1x PrimoChill PrimoFlex PRO LRT Tubing 7/16"ID 5/8" OD with 3/32" Wall - White
1x IandH Silver KillCoils
2x Bitspower rotary matte black compression fitting
2x EK Black Compression fittings
3x Yate Loon Low speed fans
2x Scythe S-Flex Fans
6x Bitspower matte black barbs
1x MX4 TIM
2x 120mm fan filters
1x 140mm fan filter
2x Sponges
My fittings are miss matched cause sidewinder ran out of what I ordered. I should have just bought them at jab tech. I wasn't to happy because they didn't offer a discount or anything like that. I will probably order the other fittings and match them all later with EK black compressions.
Finished Photos
[Orignal Post]
[Orignal Post]
[Orignal Post]
[Orignal Post]
Paint on the tape
1x XSPC RX360 rad
1x XSPC RX240 rad
2x EK FC Links
1x MX4 TIM
1x 140mm fan filter
2x Sponges
