Lousy pic but ...
X62 in push/pull front mounted with Coolermaster Masterfan 140 Air Pressure's
Seahawk X rad on the back in push pull with Coolermaster 120 Air Pressure's
Bottom & Top Intake with 2 x Coolermaster Masterfan 140 Airflow's
Temps on idle
Some rant about the Coolermaster Masterfans ...
Amazing specs in terms of airflow and air pressure ...But build quality is sub par ...
When you rise the fan speed, there's lot of oscilation ... to a point that i had to do this:
I had to create some spacing between the fan and the case chassis because the fan blades were hitting the chassis hard to a point that i thought 2 of them were completely broken.
PSU chamber is a mess in terms of wires... since i have to use cable extensions if i want sleeved cables ... it's a mess :x
