1 - 14 of 14 Posts
Ghost of Grey Fox
Hey all, this is my build log for my Metal Gear Solid themed computer. I'm a huge MGS fan and have wanted to do some sort of Metal Gear themed computer for some time now and thanks to the people at Parvum Systems I was able to finally get this ball rolling.
The main purpose for bad boy will be a computer for the man cave/I done F'ed up room:rolleyes: and a rig a can take to LAN's, the Caselabs SMA8 is a great case, just a little hard to take places
Planned Spec's
Intel i7 4790k
MSI Z97M Gaming LGA 1150
EVGA GTX 970
CORSAIR Vengeance 8GB
CORSAIR RM650
SAMSUNG 840 EVO 500G
EK-XRES 140 DDC 3.2 PWM
Swiftech APOGEE XLC
Watercool HEATKILLER GPU-X³
Alphacool 240
Alphacool 160
Aquacomputer Aquaero 6
Between life and work, mostly work, this is probably going to be a long build log but hopefully will be done for PDXLAN 26 in July. 6 months should be enough time.... right.....
So first off. THE CASE
Power LED in effect
Heads up, a lot of people don't really check the case mod forums (I never do at least.), so a better place to put it might be the Intel Build Logs or the Case Mod Work Logs section.
Can't wait to see what you do with this beauty of a case, though.
Originally Posted by Wolfsbora View Post
Majorly subbed! Excited for this.
Thanks for the subs!
Thanks for the advice, so how do I go about moving the thread?
Fluffy Fennec Foxes!
So glad you posted a link to this in the Parvum thread. Going to be a lovely ride!
Subbed, the MGS theme is badass
Originally Posted by easynator View Post
I'm subbing this for sure!
Originally Posted by Wiz766 View Post
OOoooohhhhhhhhhhhhhhhhhhhhhhhh
Thanks for the support!
Should have a small update tomorrow.
Discussion Starter · #13 ·
Haha, I'm trying, work has been unseasonably busy, finished the basement so moved the man cave down there.
Then made a hungover New Years purchase that took time away...
But I do have a small update. Been playing with placement and spacing and finding that fitting 2 radiators in my case is going to be one tight squeeze. Because of the design of the front, I cant have a radiator up front so was planning on having a small 160 radiator in back. Now wondering if I can just get by with a 240.
That is just a radiator I had around and a 60mm rad. but with 45mm, with a fan it'll be around that.
Which give me about 60mm from the back of the radiator to the back of the case.
Both radiators should be here next week so i'll actually be able to test fit.
So until they get here I'm playing with where to mount the Aquaero 6. I wasn't planning on using one but got one back on warranty so I had it around. At the moment I'm liking the idea of cutting a area on the power supply side and having it there.
Not sure if I'll have it recessed, or making it flush with the face plate.
Hopefully will have time to work on it this weekend, hopefully.
MMO Enthusiast
seems nice, subbed
1 - 14 of 14 Posts
