1 - 20 of 245 Posts
Welcome to my build log, any comments/feedback will be much appreciated.
The build will be a red, black and white theme using a Parvum L1,0 atx case.
MAIN COMPONENTS
CASE: Parvum L1.0
CPU: Intel Core i7 6700K Skylake
MB: Gigabyte Intel Z170X Gaming 7 Skylake LED ATX Motherboard
RAM: Crucial Ballistix
PSU: Corsair AX860
VGA: Gigabyte G1 gaming gtx 980 ti
PCIE SSD: Plextor M6e
HDD: Undecided
CABLES: Pexon
Lighting: Darkside LED strips
Fans: Thermaltake Riing12 and Parvum Systems F1.0
WATERCOOLING COMPONENTS
CPU BLOCK: EK
VGA BLOCK: EK
RES: Monsoon MMRS reservoirs
RADS:XSPC
PUMP: EK-D5 PWM
FITTINGS: Barrow Compression Fitting For hardline Tubing
RIGID TUBING: Acrylic
COOLANT: Mayhems
· Fusion is Future
Dont you get bored with same colour scheme every time?
following your builds for some time, waiting for someting new
Discussion Starter · #9 ·
lol I hear you but I try to make it so it fits in with the rest of my layout at home. Anyway I'm using the addition of a white this time what more do you want
I like to think my builds are still individual designs.
Originally Posted by Furious Pcs View Post
subbed for sure case sure looks big
Yes that's why I put an ATX motherboard in there to give everyone something to scale it from.
You cannot get a true sense of scale from all the pictures I have seen on the internet.
Discussion Starter · #16 ·
Originally Posted by Mads1 View Post
Them monsoon mmrs res look quite nice, i looked at a black and crome one a little while back, not many places sell them in the UK yet.
I ordered mine from Performance-PCs.com
Discussion Starter · #18 ·
Yes $57.80 postage is high but I think it is worth it to get the look I'm going for.
I went for a standard case this time to save time, the only thing I might change on it is the mid wall. I would like the main board power and data cable cut-outs to line up and be closer to the motherboard. Also cover the SSD drive mounts in order to mount the res.
Like this
Discussion Starter · #20 ·
That's why I didn't get a custom design this time as wanted to start it now, plus I will not need to mod it too much.
Yes I think I'll make some extra cut-outs in the mid wall to take the cables then make a panel like this.
1 - 20 of 245 Posts
