1 - 20 of 242 Posts
Welcome to my build log.
This build is not based round any particular theme just the motherboard, the new Rampage V Edition 10
It will consist of a Parvum M1.0 ATX case in black.
This will be my 5th Parvum build and just in case anyone was wondering I am not associated or sponsored by Parvum or anyone else. like most of you I use my own hard earned cash.
Why do I use Parvum cases? because of there versatility, ability to purchase spare panels and custom parts. Always handy if you make a mistake drilling/cutting or just change your mind about the colour.
Don't get me wrong there are plenty of other fantastic cases out there but these suit my needs best.
MAIN COMPONENTS
CASE: Parvum M1.0
CPU: Intel Core i7 6800K Broadwell
MB: Asus Rampage V Edition 10
RAM: Corsair Dominator Platinum
PSU: Corsair HX850i
VGA: Asus GTX 1080 FE
HDD: Undecided
CABLES: Pexon
Lighting: Undecided
Fans: Corsair ML120
WATERCOOLING COMPONENTS
CPU Block: EK
VGA Bock: EK
Backplate: EK
RES: EK-RES X3
RADS: XSPC
PUMP: EK-D5 PWM
FITTINGS: EK-HDC Fitting 12mm G1/4 - Nickel
TUBING: Bitspower None Chamfer Brass Link Tubing 12mm od
COOLANT: Mayhems
I have lots of goodies to photograph and I will upload them on the weekend.
Discussion Starter · #8 ·
· Fluffy Fennec Foxes!
Subbing for the ride!
Very nice! Just got my MSI Gaming-X GTX 1080 and the ASUS Rampage V Black Edition 10th anniversary mobo in my rig too
FANTASTIC mobo, although i can't seem to get the SupremeFX hi-fi AMP/DAC combo to work. I have the 6 pin and USB cable plugged into it and no matter what i do with drivers etc.. i get no sound from it.
Parvum builds are sick as hell, so i'm looking forward to seeing it. I have some pictures of my build (only ipod pics so they're not the best) i'll upload them for you guys to see if you're interested.
Good Luck!!
Discussion Starter · #19 ·
Discussion Starter · #20 ·
Good Luck!!
Unfortunately I'm unable to help you with that as I have not got mine up and running yet.
The only thing I can think of is look in the bios you may need to point it to the device.
1 - 20 of 242 Posts
