Hey Guys,
here's my Build Log around a Parvum S2.5 mATX case. Some modifications have been done to the case so it fits a 'organic' theme I guess.
Following pictures show first renders of the case:
As mentioned already, I'm aiming for a 'organic' theme and with that I watercool the PC and mod some parts along with sleeving the cables myself.
I'm doing all of this the first time (not the building a PC part), so advices are well appreciated!
The colors I will be using are mainly matt/glossy black, silver and few accents with mint green (#00ffb9ish)
I've been constantly upgrading my hardware since the beginning of the year to the point where I pretty much have a whole new system today.
Main components (reused):
Case: Parvum S2.5 mATX
CPU: Intel Core i7 4790k
GPU: EVGA GTX 980 ACX 2.0
RAM: HyperX Fury 4x4GB DDR3 1866MHz
Motherboard: Asus Z97 Gryphon mATX
PSU: bequiet! Straight Power 10 550W (semi-modular)
Watercooling components:
CPU-Block: EK-Supremacy EVO - Acetal+Nickel
GPU-Block: EK-FC980 GTX - Acetal
GPU-Backplate: EK-FC980 GTX Backplate - Black Nickel Black
Reservoir: Bitspower Water Tank Z-Multi 150mm clear
Reservoir mount: Singularity Computers CORE SINGLE V3
Radiators: 2x EK-CoolStream SE 240 26mm
D5 Pump: EK
D5 Pump top: Bitspower Premium D5 mod kit
Fans: 4x Noiseblocker Blacksilent PRO PL-PS
Fan splitter: ModMyToys 4x 4-pin PWM
Fittings: Alphacool HT 13mm HardTube - knurled - deep black
Tubing: Alphacool Eisrohr 13/10mm satin
Fluid: Mayhems Clear mixed with emerald green and dark blue dye
Miscellaneous:
Sleeving: MDPC-X black & Shakmods "dark green" expandable 4mm sleeve
Sleeving kit: Lamptron
RAM "cooler": XSPC Universal heatsink
Chapters
