I started this build quite a while ago (January 2018). It took a long time to finish, mostly due to lack of free time. I finally finished up in September 2019. Below is a fairly verbose log of the process. Feel free to skip to the next post to see final pictures/video. All images (besides some final ones) will be in spoiler tags to cut down on scrolling.
I would opt for one long post with the entire log, but I guess things have changed since I last posted on here. The process of attaching images seems overly complicated. So I will be breaking the log into individual posts. This may take a day or so to finish.
The build is largely inspired by a timelapse build I saw on youtube. But I added my own flavor to it, so it's quite a bit different.
As someone who owns 2 cats (at the time of the build, 3 now), I was very aware of the open-concept nature of the case. I was optimistic that I could deal with it and the cats, but the in the end, it was a bit too impractical. I'll explain near of the end of the build, but I'll be repurposing this build for something new.
Anyways, hope you enjoy the log and I apologize for the length! I didn't want to post a log while in progress, since it would have dragged on for so long.
Table of Contents:
1.) Parts List and Unboxing P90
2.) Attaching Acrylic Sheets to P90
3.) Attaching Motherboard
4.) Attaching GPU
5.) Cutting Hole For Fan Controller
6.) Cutting Holes for Fans and Radiators
7.) Hacking Case to Accommodate Air Flow and Fan Controller
8.) Assembling and Attaching Reservoirs
9.) Cutting Holes for Exhaust Fans and Installing Pumps
10.) Cutting Holes for GPU Riser Cable
11.) Cutting Holes for GPU/Motherboard Cables
12.) Changing Motherboard Mounting Screws and Hooking Up GPU and Fans
13.) Fully Assembled Case (Minus Tubing)
14.) Fittings, Cables, etc. Arrived and Beginning of Tube Bending
15.) Drain Valve Construction and Reservoir Outlet Tubing
16.) First and Second Attempts at Reservoir Inlet Tubes
17.) Radiator Tubes and Reservoir Aqua Tubes
18.) Assembling GPU and Installing CPU, RAM and SSD
19.) Cleaning Radiators, Peeling Off Paper From Acrylic and Air Testing Loops
20.) Blitz Part 2
21.) Final Pictures and Video
Table of Contents:
4.) Attaching GPU
20.) Blitz Part 2
