1 - 1 of 1 Posts
Hello,
I’m AK MODs from Taiwan. I am excited to show my work and hopefully learn a lot along the way.
My project is called Praetor. I will enter with the C700P. The 4 bar handles will be polishing finished and the chassis will have a rough black finish. I will add a bit of aluminum accent inside. It will have glass on both sides with mirror finish. I will try to keep it simple with a clean liquid cooling setup.
Hardware:
Asus Maximus X Formula
Cooler Master V750
Cooler Master MasterFan Pro 120
Cooler Master COSMOS C700P
Nvidia Geforce GTX 1080 Founders Edition
Zadak Shield 8GX4 DDR4
Zadak Shield 240 SSD
Cablemod Custom Cable
Water cooling:
Bitspower Nvidia GTX 1080 Special Edition
Bitspower Fitting
Bitspower Radiator 360
Bitspower Brass Hard Tubing
Cooler Master MasterLiquid Maker 240
I want to thanks so much to all of my sponsors which I have a pleasure to work with!
1 - 1 of 1 Posts
