1 - 20 of 126 Posts
iPwn
Discussion Starter · #1 · (Edited)
Thanks Caselabs! XXX R.I.P. XXX
Specs...
  • CaseLabs Mercury S8S Chassis - Window panels, Vented top
  • Intel i9 9900K Processor
  • ASUS Maximus XI Formula Motherboard
  • Nvidia RTX 3080 Ti FE Video Card
  • ASUS Thor 850W Power Supply
  • G.SKILL Trident Z RGB 32GB RAM
  • Samsung 970 Pro 1TB m.2 SSD (Main)
  • Western Digital Blue 2TB m.2 SSD (Storage)
  • Western Digital Gold 2TB HDD (Backup)
  • Noctua Industrial PPC 3000RPM 120MM PWM Fans (White Rubber & mounting kit)
  • Custom water loop
PROGRESS STATUS >>>>
  • RTX 3080 Ti FE water cooling.
  • Rebuild loop (New CPU block; matte black soft tubing, new drain valve, new pump, new fittings)
  • Cooler Master MasterFan ARGB HUB.
>> Current state...
>> Past setup and build...
iPwn
Originally Posted by KShirza1 View Post
Some drives... (RAID 0 and remote folders)
Should this go in? are these even relevant anymore?
Lighting
980Ti Before block
If it's going to clutter the look of the front of the case, or your going to sacrifice rad space because of it.... I say no.
Me personally would install a slim or slot loading drive if the above 2 issues weren't a problem.
iPwn
Just the thought of running cables to it alone is annoying haha
I'm on the same page. Thanks!
Computer Studio
1 - 20 of 126 Posts
