1 - 20 of 840 Posts
Hardware Parts:
Storage
Samsung 960 Pro 1TB M.2
Samsung 960 Evo 1TB M.2
Western Digital 6TB (Green)
Western Digital 6TB (Blue)
Samsung Evo 850 2TB(Raid 0)
Asus Rampage V Edition 10
CPU Processor
Intel Core i7-6950X 10-Core
Memory
Corsair Dominatior Platinum 32 GB (4x8GB) 3200 Mhz Blackout Edition
Case & Case Parts
CaseLabs THW10 Computer Case
Mod-One Custom Made Feet
Bottom Accessory Mount - Style: 140mm Single (140.1)
Flex-Bay (120.1)
Flex-Bay (120.1)
Flex-Bay (140.2)
Flex-Bay (140.3)
Flex-Bay (140.3)
Flex-Bay 5.25 Device Mount - Short
Flex-Bay 5.25 Device Mount - Short HD
Flex-Bay 5.25 Device Mount - Short SD
Flex-bay 5.25 Device Mount - Short Nonconforming
Power Supply & Accessories
EVGA SuperNOVA 1600 T2
MDPC-X Sleeving (Black)
Darkside Sleeving 2mm (Black)
16 AWG Wire
18 AWG Wire
AlphaWire ECO 22 AWG Wire
Belden 22 AWG Wire
Belden 24 AWG Wire
Belden 26 AWG Wire
JMT Long Version Terminals(Female)
Molex 16 AWG Terminals(Female)
JMT Molex Terminals (Male & Female)
JMT Sata Terminals Long & Short
JMT Dupont Terminals
JMT Black Connectrs
Young Yak Fan Terminals (Male & Female)
Graphic Card
Nvidia GeForce GTX Titan X
Lighting
Darkside LED UV 12"
Darkside LED UV 5"
Darkside LED RGB 19"
Darkside LED UV 5mm
AquaCompter LED RGB 5mm
Cables
All Cables have been Created from Scratch
Case Fans
BeQuiet Silent Wings 3 140 PWM
BeQuiet Silent Wings 3 120 PWM
Other Hardware Parts
Aquacomputer HUBBY7 internal USB 2.0 Hub
Aquacomputer SPLITTY9 Splitter
Aquacomputer Kryo M.2 PCIe 3.0
Aquacomputer Temperature Sensor 70 cm for VISION
Dust Filters
DEMCiflex Magnetic Fan Dust Filter Flex-Bay 140.3
DEMCiflex Magnetic Fan Dust Filter Flex-Bay 120.1
DEMCiflex Magnetic Fan Dust Filter Flex-Bay 140.2
Capture Card
Magewell 4K Plus
WaterCooling Parts
Waterblocks
EK-FB ASUS R5-E10 Monoblock RGB Edition
WaterCool HeatKiller IV for Titan X (Pascal) - Acetal Nickel
Waterblock Accessories
Thermal Girzzly Thermal Compound
Thermal Girzzly Thermal Pads
WaterCool HeatKiller IV eBC - Backplate for GTX 1080, 1070 and Titan X (Pascal)
VISION connection terminal for kryographics
Aquacomputer Filter
Radiators
Hardware Labs Black Ice SR2 Multiport 560mm
Hardware Labs Black Ice SR2 Multiport 420mm
Radiator Accessories
Hardware Labs Black Ice Mount Screws M4 x 30mm Black
Hardware Labs Black Ice Mount Screws M4 x 28mm Black
Hardware Labs Black Ice Mount Screws M4 x 8mm Black
Hardware Labs Black Ice Mount Screws M4 x 5mm Black
PC Radiator Mount Screws M4 x 35mm Black
PC Radiator Gasket 3mm Thick
Fans
Corsair 140 ML Pro Premium Magnetic Levitation
Fan Controller
Aquacomputer Aquaero 6 XT Blue
Aquacomputer Power Adjust 3
Fan Controller Accessories
Aquacomputer Passive Heatsink
Aquacomputer Front Faceplate for Aquaero 5/6 XT Aluminum - Black
Aquacomputer Bezel for Power Adjust 3
VISION Touch table top unit, matte nickel plating, IR receiver and ambient temperature sensor
Tubing
Mayhems 16mm Borosilicate Glass
Pumps
Aquacomputer D5 Pump Mechanics With USB and Aquabus Interface
D5 Pump Top & Accessories
EK-XTOP Revo Dual D5 Serial
HeatKiller Rubber anti-vibrations Screws
Coolant
Mayhem XT-1 Nuke - UV Blue
Mayhems Blitz Part One
Mayhems Blitz Part Two
Fittings
Bitspower Stop Fitting
Bitspower LED Stop Fitting
EK LED Stop Fitting
Aquacomputer LED Stop Fitting
Aquacomputer Temperature Sensor - Inner/Outer Thread G1/4
Aquacomputer Temperature Sensor - Inner/Outer Thread G1/4 (Vision Version)
Bitspower Premium G1/4" Stop Fitting
Bitspower Low Profile G1/4" Stop Fitting
Bitspower Dual Rotary Angle Extender
Bitspower 90-Degree With Dual Rotary Extender
Bitspower 60-Degree Extender
Bitspower 30-Degree Extender
Bitspower 45-Degree Extender
EK-AF Pass-Through
EK-AF Fill-Port
Bitspower Matte Black Dual Rotary Mini Valve With G1/4" Extender
Aquacomputer G1/4 Temperature Sensor
Aquacomputer G1/4 Temperature Sensor(Vision Version)
Aquacomputer G1/4 Flow Indicator | High Flow - USB
Bitspower G1/4" Matte Black Enhance Multi-Link For OD 16MM
Bitspower Matt Black T-Block With Triple IG1/4"
Bitspower 5mm Spacer Extender Adapter - G1/4 Male/Male - Matt Black
Bitspower 15mm Spacer Extender Adapter - G1/4 Male/Male - Matt Black
Bitspower 30mm Spacer Extender Adapter - G1/4 Male/Male - Matt Black
Bitspower 3-way Splitter, T Block Crossconnect Adapter - Matte Black
Bitspower 2-way L Block Crossconnect Adapter - Matte Black
Bitspower Plus Allot More
Reservoirs
HeatKiller Tube 200
HeatKiller Tube 200
Aquacomputer Aquatube Reservoir | Black
Reservoirs Accessories
HeatKiller Tube Multi Top 200
HeatKiller Tube Basic Mount
HeatKiller Tube S LED Blue
Aquacomputer AquaJet Flush Tube for Aquatube G1/4
Aquacomputer Aquabay AT Rev 1.5 Baydream
Aquacomputer Faceplate for Aquatube - Aluminum - Black
Color Index
Green = Already Have
Blue = Waiting to be Shipped
Red = Need to Buy
Subscribed love the caselabs cases:thumb:
I've just received my tracking number for my SMA8 should be here in 4 days(from a European re-seller)
I have a question about the 120mm extended top you just purchased, are you planning on installing a radiator in there? I wanted to do this myself but I've not seen any pictures of it done..
Thanks Day and good luck
Discussion Starter #10
I'm planning on putting my radiator up their. You will need the barb drop-in radiator bracket.
Here is SMA8 with Radiator ontop:
Thanks Revan that's what I've been looking for
I better get my order in with a 3/4 week wait plus shipping to the UK...
Day
Discussion Starter #13
Originally Posted by DrFreeman35 View Post
I don't think that push/pull rad will fit in the top of the SMA8, only extended top they have on site is 39mm for single wide. If so, no way that will fit. Is there something I'm missing?
I don't know what SMA8 has but I know SM8 has a 120mm extended top. Tops may be different for that line.
Discussion Starter #20
It's weird you found that picture Revan, I wonder what that person did. Why they were showing that up there, would be a good option. Especially since basement gets cramped, I'll be fitting a 560 and 240 in basement of the SMA8
It's most likely a custom mod using the extended top as a reference.
1 - 20 of 840 Posts
