Project: Heatripper Threadkiller has begun!
The name comes from a mash-up of the CPU (Threadripper) and most of the components of the loop (Watercool's Heatkiller series).
Going with the HEDT platform because I've never built one before and I figured it was about time. I don't actually need lots of cores/threads but I want the build experience. Who knows -- maybe once I get them I'll start using them...
This build started with the idea that I needed to get away from my "comfort zone" brands -- EVGA for GPUs, ASUS for mainboards, and EK for most loop components. I also want this to be a show build at least partially -- enough to want a vertical GPU and a coolant with some sort of effect (Mayhems Pastel or UFO Technologies Cryo-Chillz), but not enough to do hard tubing.
Also notable is that I am going to keep this build RGB-free if I can manage it.
Heatripper Threadkiller Settings and Long-Term Test
Purchases:
From Best Buy (04/27/18):
Logitech G Pro RGB USB Keyboard
Logitech G Pro RGB USB Mouse
Logitech G633 7.1 RGB USB Headset
Total: $263.88 including tax
From Microcenter (04/27/18):
Logitech G440 Hard Gaming Mouse Mat
Total: $32.25 including tax
From Newegg (03/12/18):
Corsair HX1000i Power Supply
Total: $229.99 including
From CableMod (03/08/18):
Custom ModMesh Cable Set w/ full Pro upgrade for Corsair HX1000i
Total: $246.80 including shipping
From Performance PCs (03/05/18):
Be Quiet! Silent Wings 3 - 120mm PWM High-Speed Fan (4)
Total: $95.76 including shipping
From EKWB (02/26/18):
EKWB EK-FB ASRock X399 RGB Monoblock - Nickel
Total: $184.45 including shipping
From Performance PCs (02/26/18):
Be Quiet! Silent Wings 3 - 120mm PWM High-Speed Fan (2)
Total: $59.22 including shipping
From Microcenter (02/16/18):
AMD Ryzen Threadripper 1950X
ASRock X399 Taichi
PrimoChill PrimoFlex Advanced LRT 10/16mm - Crystal Clear (2)
Enermax LiqTech 280 AIO
Noctua NT-H1 Thermal Paste
Total: $1,523.62 including tax
From Microcenter (02/09/18):
AOC Agon AG271UG 27" IPS 4K UHD Gaming LED Monitor (Returned -$462.37)
Whoosh Screen Shine
Total: $16.12 including tax
From Watercool (02/08/18):
Watercool MO-RA3 360 LT - White
Watercool MO-RA3 360 Fan Grill Diamond - White
Watercool HEATKILLER Tube - MO-RA3 Adapter - Black
Total: $232.22 including shipping
From Performance PCs (02/08/18):
Be Quiet! Silent Wings 3 - 120mm PWM High-Speed Fan (1)
Silverstone CPF01-D PWM Fan Splitter Cable
ModRight Black-Out Series 24" 4-Pin PWM Extension Cable
Koolance QD3 Quick Disconnect No-Spill Coupling, Female Compression 10mm x 16mm Black (2)
Koolance QD3 Quick Disconnect No-Spill Coupling, Male Compression 10mm x 16mm Black (2)
Mayhems Pastel Coolant - 1 Liter - Yellow (1)
Gelid GC-Extreme Thermal Compound
Total: $127.83 including shipping
From FrozenCPU (02/07/18):
Watercool MO-RA3 Radiator Stand Set - Acetal
Total: $42.34 including shipping
From ModMyMods (01/29/18):
Barrow G1/4" Thread 3/8" ID 5/8" OD Compression Fitting - Black (14)
Total: $74.94 including shipping
From NewEgg (01/29/18):
G.Skill Trident Z F4-3200C14Q-32GTZRX 4x8GB
Corsair Gaming PBT Double-shot Keycaps Full 104/105-Keyset - White
Total: $579.98 including shipping
From Performance PCs (01/29/18):
PrimoChill Praxis WetBench - White/Black
Hardware Labs Black Ice Nemesis 480 GTX
Hardware Labs Black Ice Mount Screws M4x30mm Black (4 sets)
Be Quiet! Silent Wings 3 120mm PWM High-Speed Fan (8)
DEMCiflex Magnetic Fan Dust Filter - Custom Filter for Quadruple 120mm Radiators
XSPC LCD Temperature Display (Blue/White) V2 + G1/4" Inline Sensor
Swiftech 8-Way PWM Splitter Box - SATA
Mayhems Pastel Coolant - 1 Liter - Yellow (2)
Total: $641.84 including shipping
From Nvidia (01/25/18):
Nvidia GTX Titan Xp Jedi Order Collector's Edition
Total: $1,223.63 including shipping
From Watercool (01/21/18):
Watercool Heatkiller IV Pro for Threadripper ACRYL NICKEL-BLACK
Watercool Heatkiller IV for TITAN X and GTX 1080Ti - ACRYL Ni-Bl
Watercool Heatkiller IV eBC - Backplate for GTX 1080, 1080Ti, 1070 and Titan X
Watercool WCP D5-VARIO with Heatkiller D5-TOP
Watercool Heatkiller Tube 150
Watercool Option - Alternative MultiPort top
Watercool Heatkiller Tube - basic mounting kit
Watercool Heatkiller Tube - 120mm fan adapter (pair)
Total: $513.15 including shipping
Total Spent As Of 04/27/18: $6,088.02
Reusing from previous build(s):
Samsung 960 Pro 2TB M.2 NVMe
Samsung 950 Pro 512GB M.2 NVMe
Corsair HX750i 750W Power Supply
Acer XB270HU bprz 1440p 144Hz G-Sync Gaming Monitor
Corsair Gaming K70 RGB RAPIDFIRE USB Keyboard
Corsair Gaming GLAIVE RGB USB Mouse
Corsair Gaming VOID RGB USB Headset
Corsair Gaming MM400 Compact High-Speed Mouse Mat
Purchases:
ASRock X399 Taichi
Whoosh Screen Shine
