1 - 20 of 59 Posts
My New gaming rig with Watercooling, Just started building it tonight. Have to wait for a few items to come in. Designed for 4K.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard: Asus ROG MAXIMUS VIII HERO ALPHA ATX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 16GB (4 x 4GB) DDR4-3200 Memory
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Seagate 2TB 3.5" 7200RPM Hybrid Internal Hard Drive
Video Card: MSI GeForce GTX 1080 8GB GAMING X 8G Video Card
Case: Corsair Air 540 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: LG BH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 10 Home Full 32/64-bit
Monitor: Dell U2715H 27.0" 60Hz Monitor
Keyboard: Razer Orbweaver Elite Mechanical Gaming Keypad Wired Gaming Keyboard
Keyboard: Corsair K70 RGB Wired Gaming Keyboard
Mouse: Razer DeathAdder Chroma Wired Optical Mouse
Full Link: http://pcpartpicker.com/list/Kyv29W
TV: Samsung SUHD 4K (I mirrored the image on my monitor and TV)
Other: Corsair Lapdog
Cables: CableMod E-Series P2 - Black
Fans: Thermaltake Riing 12 RGB LED 120mm
Fans: BeQuiet Silent Wings 2 140mm
WaterCooling Parts:
CPU Block: XSPC RayStorm Pro Black WaterBlock, Intel CPU, Blue LEDs
GPU Block: EK-FC1080 GTX TF6 - Nickel Plated Copper Water Block with Acetal Top for MSI GeForce® GTX 1080
Coolant: Ice Dragon Cooling Nanofluid Coolant-250ml (Version 2016)
Dye: Mayhems Non Stain Blue Dye - 15ml
Fittings: Bitspower Premium G1/4" Matte Black Stop Fitting
Fittings: Barrow 90 Degree Dual Ended Multi-Link Adapter - 12mm OD Rigid Tube - Black
Fittings: Barrow G1/4" 90 Degree Rotary Multi-Link Adapter - 12mm OD Rigid Tube - Black
Fittings: Barrow G1/4" Multi-Link Adapter - 12mm OD Rigid Tube - Black
Tubing: Bitspower Non Chamfer PETG 12mm OD Tube Length 500mm
Radiator: Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
Radiator: Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 240mm
Res/Pump: EK-XRES 140 Revo D5 PWM
Discussion Starter #6
Originally Posted by NeeqOne View Post
I saw your post on reddit. Have you considered upgrading the S8S to S8 to get a bit of room for the GPU waterblock? You can also replace the GPU with a reference one.
This is an entirely different PC. The one you saw on reddit was my Editing PC. I need to take a look and see how much it would cost to grab everything. I would need front and back + Front cover and new side doors for both sides.
Discussion Starter #10
^ I Barely Had Enough Tubing. I just Made it with zero extra tubing.
^ I was trying for a Darker Blue, I just couldn't get the color any darker.
^ So Much for Seeing the flow Wheel. I had an extra one laying around. I would be a bit annoyed if I paid for it for this build and I couldn't see anything.
^ Then I ran out of Fluid. That one 60mm radiators holds allot.
So far the only issue is with the Hardware Labs 240 SR2. It's a bit noisy when the liquid goes up and empty's into the radiator. I'm hoping it's because I didn't have enough liquid and theirs air in the loop.
Discussion Starter #12
Originally Posted by BornEvil View Post
that blue looks nice!
can you actually see the the flow indicator with the pastel coolant?
Sorry for the late reply, I haven't had the PC standing up yet. Since I don't have enough fluid yet. I want to say No. I will see shortly.
Discussion Starter #15
Originally Posted by bishop161 View Post
Hey mate. Very nice build. I was wondering how do you handle draining the loop. Im looking to mount my pump/res just like you did. Do you find that pump is loud.
According to information supplied to me by the company. Their is no need to drain the loop The coolant is designed to never be drained. Why theirs no drain found in my loop. If I need to theirs a port under the res I can use to drain everything out.
As long as you have some kind of anti vibration attached between the Rad & bracket. You will not hear it. Plus the fans will muffle most of the sound even if you have no anti vibration material. I always design my PC to be deadly silent, My fans don't even hit 900 rpms. You can not even hear if it's on or not.
It's the second time using this pump. I have one pump in my Gaming Rig as seen in this build and another in my video editing build, They both been perfect. Not to mention most of the D5 pumps are just re-branded. If you buy the pump from say AlphaCool it will be the same if you bought it from Swiftech.
1 - 20 of 59 Posts
