141 - 146 of 146 Posts
Im doing this same sort of thing but in the LoneIndustries L1. I have the same motherboard but pretty tall ram. Did your scythe kozuti interfere with the ram slots on the asrock board? Could you please post a pic or two of the kozuti-ram clearance either way? Ill be sure to take a bunch of pics when i slap the L1 together
Discussion Starter · #142 ·
As requested. The RAM has very little clearance issues with the Kozuti and the Asrock board.
Does one of the ram sticks actually end up partly under the cooler? Its a bit hard to tell from this angle.
Discussion Starter · #144 ·
It clears the heatsink by just a hair I'd have to say. You might have a bit more trouble with taller sticks. It's hard to say really. There is a little bit of play with how you can position the heatsink.
