1 - 19 of 19 Posts
Introduction
Hello all, before starting i ask you to forgive me if i'll write something wrong since i'm Italian. Time has come to build the new rig, i was thinking do to that with the new year, but with Black Friday and Cyber Monday i found nice deals especially on Amazon.fr and Amazon.de. In the beginning the name of the build was "Project Arctic Pascal" then i found a sweat deal on a G-Sync monitor so that's why the new name.
Components:
  • Case: Corsair 760T Black
  • PSU: EVGA Supernova 750W G2
  • CPU: Intel i5 6600k
  • Cooler: EKWB Predator 360
  • Motherboard: Asus Maximus VIII Hero Z170
  • RAM: G.Skill TridentZ 4x8GB 2800Mhz CL15
  • GPU: Gigabyte GTX970 Windforce 3 OC
  • OS Drive: Samsung 950 Pro m.2 NVMe
  • Game Drive: Sandisk Ultra II 960GB
  • Data Drive: Western Digital Red 2TB
Devices:
  • Monitor Dell S2716DG 2560x1440 144Hz G-Sync
  • Speaker: Razer Leviathan
  • Keyboard: Razer Blackwidow Chroma
  • Mouse: Razer Taipan
  • NAS: Synology DS115j
Discussion Starter · #2 ·
Ok time for some picture as components gets here
This project is probably ready later for new GeForce Pascal GPU... Depend from NVIDIA, we still don't know when is landing from orbit appointed.
Probably Spring 2016.
I think you should immediately to change CPU in i7-6700K.
That's only model capable overclocked to work similar and 20% slower in multi applications than i7-5820K and i7-5930K and he will need you for Windows 10.
Example buying 4x8GB i5-6600K DDR4 instead 2x8GB and i7-6700K is not small mistake only you will not see that now.
Someone to ask me I would install single 8GB memory only to save for i7-6700K and than install later better kit.
You don't need even 16GB of memory ... 10-12 is enough... but even if you plan something where 4x8GB need you in that situation even more need you i7.
Listen me, for 2-3 years will remember what I told you when your i7 overclocked beat AMD Zen and give you same score as newest i7 generation on default clock.
You are right, but let's say i'm building this, waiting Pascal and Kaby/Cannon Lake (if Intel will made them compatible with Z170) because at the moment i don't want to spend 450€ or more for a CPU
New arrives at home
Discussion Starter · #6 ·
And the BEAST is here
Now i can start "build" and test it on the benchcase
The Hyper Evo is temporary waiting to choose and buy the watercooling components.
Discussion Starter · #8 ·
Aborted custom loop
Discussion Starter · #9 ·
Finally some time! Today i decided to build and test all components on the test bench. All working and also 0 dead pixel on the new monitor
Ordered all the stuff from EKWB shop
Btw i ordered also the cheap Aquaero 6 Pro
Discussion Starter · #11 ·
Sorry for late update but the orders are slowing coming in
Here the two Alphaccool radiator, EK coolant, Aquacomputer pump, Phobya 8 way splitter and some sleeved sata. The mini Alphacool dissy is for the Samsung 950 Pro chip as i saw on another build
Discussion Starter · #12 ·
Just come back from a trip to Barcellona and i found a surprise :V Now i just miss the Aquaero and Ensourced cable that btw are in Italy since 2 January, 150km from here where i live, i love italian mail service...
Discussion Starter · #13 ·
Started to build the rig at last. Here the GTX 970 hoping to have done all right :V
Discussion Starter · #14 ·
Assembled mobo+cpu block
Also a screenshot of the full setup using the old pc
There is also a new tv, a nice 40" 4k
Discussion Starter · #15 ·
And at last i flushed the radiators, assembled the aquaero pump + EK Top and drain system
Discussion Starter · #16 ·
I forgot this nice surprise, one of the plug is broken, fortunally i don't need it since i'll put the drain with the ball valve
Discussion Starter · #17 ·
New Case, new cooler
Modded 760T
Dead thread?
Discussion Starter · #19 ·
Yeah
I posted the picture in another thread
1 - 19 of 19 Posts
