1 - 9 of 9 Posts
dimensions
400x200x315mm ~ 25 liters
top/bottom/psu panel - 3mm stainless steel
motherboard panel - 2mm aluminium
profiles - solid alu 10x10mm aluminium
total weight (case only + handle + rubber feets) about 1,65kg
Hardware Princess
How did you get all the wiring to look so nice? Like the system is on but I don't even see any wires
Discussion Starter #6 (Edited)
custom wires/custom lengths from 1mm electrical cable
4 and 8 pin eps - very short
24pin custom (can be better but i make it little longer to fit even shorter psu like ax860)
pci-e cables 2x8pin to 8pin corsair (8 wires only in total) (not all pins in 8pin pci-e are filled but original one from corsair is even weaker bcoz its use 7 pin from psu side (3x12V + 4xGND)
RGB Rainbow Vomit!
That is absolutely superb. My only critique is that lonely 2.5" drive mounted to the back.
On a side note, Akasa ProSlim SATA cables have lower profile head with thinner and very flexible cable.
Discussion Starter #8
silverstone slim cables are even better
pc has 1tb nvme m.2 and I want to put 6x500gb sata in raid0 - so its really no space to put them, just on back
1 - 9 of 9 Posts
