Hey guys!
A week ago, I received all of my WC components, so I decided to single-sleeve my PSU and work on cable management before I built my new loop. Sleeving will be MDPC-X black and light blue. Unfortunately, I'm a complete noob so hopefully this doesn't turn out too badly
WC Components:
CPU Block: HeatKiller 3.0 LT
Rad: XSPC RX360
GPU Block: HeatKiller X3 58XX
Tubing: 12ft 1/2" ID Feser UV Blue
Fittings: 12 Bitspower Black Sparkle Barbs
Clamps: 12x Koolance clamps
Fans: 6x Yate Loon Mediums (unfortunately from Performance-Pc's)
Reservoir: XSPC Dual Bay
Pump: MCP 655
Misc: Danger Den Fillport
I realized that I had no way to drain my loop... Thankfully my parents had to go to Menards, so I hopped with them and found a cheap t-fitting and stopper for 60 cents each! They don't really match my color scheme...but whatever lol
Before pics:
Interior
The REAL mess behind the motherboard:
The PSU original sleeving (not too bad, but I want my own colors and uni-sleeving):
Thanks MDPC-X!
Power supply opened up, as sleeving was all the way inside before:
EDIT: As a quick question, does anyone know how I can avoid using the inverter for the cold cathodes? Those wires are hard to hide and really annoying >.<
And my fingers are KILLING me from sleeving... Kingwin sucks at organizing their cables... wires criss-crossed every which way and tangled together... So many burns
No build is complete without an injury! - from pulling out an ATX pin too fast
After pics:
WC Components:
Rad: XSPC RX360
Pump: MCP 655
Before pics:
Interior
Thanks MDPC-X!
After pics:
