Welcome to my new build log - A Robocop themed build housed in a modified 900D. This build be slower going than my last because of the modifications to the case chassis and the 900D outer casing will be going to the body shop for some paint work.
Let's get this started!
I'll be recycling some core components from my previous build "900CSQ", namely the motherboard, GPU's and Processor, but other than that everything will be all-new. With the theme being "Robocop" the color scheme is strictly Silver, Gray, Black and Metallic. Here's a breakdown of the components:
Main Components
CPU: 3930k
Memory: 16GB Corsair Dominator GT
GPU: 3 way SLI GTX 780's
Motherboard: Asus Rampage Extreme IV
Power Supply: Corsair AX1200
SSD: Samsung 840 Pro 512Gb
Watercooling Components
2 x Aquacomputer Modularity 480 Single Circuit
1 x Aquacomputer Modularity 240 Single Circuit
2 x Aquacomputer Aqualis Reservoirs
4 x MCP35X Pumps
2 x Aquacomputer Dual DDC Pump Top
1 x EK Clean CSQ Full Nickel CPU Waterblock
2 x EK Dominator Ram Blocks w/ Black Top
3 x EK Clean CSQ Nickel Plexi 780 Waterblocks w/ Backplates
1 x XSPC Rampage Extreme IV Waterblock
Misc
All Bitspower Black Sparkle Fitttings
All Acrylic Tubing
All Noiseblocker Fans
Custom AX1200 Modular Cables made by Ensourced Custom Sleeved Cables
Clear Primohchill DI Water
1/29/2014 UPDATE:
Build is complete!
LINK TO FINAL PICS http://www.overclock.net/t/1426275/build-log-robocop-finished/840#post_21723501
