Rowey's Watercooled Phantom
2011-2012
Brief:
My current setup in My Phantom, is the growing old socket 775. I'm sick of being told Im old fashioned and that Im hording old technology.
So I've spent a lot of time reading reviews and listing together parts and Im going to rip out my 775 setup and replace it with brand spanking new 1155 hardware.
Cooling-wise, my H50 isn't quite cutting it for me anymore and I can't go on and spend all this money on my new 1155 setup and continue to use my cheapskate, pre-filled and loud watercooling solution. So I've been doing a lot of research and Im going to watercool my new chip properly.
Old Hardware:
- Gigabyte GA-EP45 UD3P REV 1.0
- C2Q Q8400
- 4GB (2x2GB) Corsair Dominator 1066mhz
- Asus GTX 460 Directcu top
Components
- Asus P8Z68-V
- i5 2500K
- 16GB (4x4GB) Corsair Vengeance 1600mhz (Blue)
- Corsair 120GB Force series 3
- Palit GTX 580 1.5GB
- XSPC Rasa 750 RS360
- Primochill PrimoFlex Pro LRT 1/2" ID - 3/4" OD (Blue)
- EK PSC Compression Fitting for 1/2" ID - 3/4" OD (Black)
- Scythe Gentle Typhoon 120mm 1850 RPM
- Pulse Modding BioClear PHN 10ml Concentrated Biocide
- EK-FC580 Acetal/copper
If anybody has any tips or suggestions or opinions, or things i should know before i start putting the loop together i would really appreciate them because this is my first time doing anything like this.
