1 - 20 of 79 Posts
First of all I'd like to thank Alphacool and Mayhems for supporting this project.
Special thanks to Adam from AD Modz, thanks to whom it all started!
I've been searching for a large and simple case that can fit two 60mm thick 480 rads. I haven't found one that would have a layout i like so i decided to make one myself. I'm much more of a diy guy than computer head so there is no render models of the build, thread won't be full of awesome professional pictures and it might be not very neat and organised.
Disappointment for most. I will, however, try my best to provide as much details and up to date info on what's being done.
Actual state of my pc(pretty much all hardware is going to be transfered to the new case):
Now the new case...
I wanted something simple, minimalistic but strong and big. Two 480 rads fitted without problems(push/pull possible on both) with an option of adding more rads if needed(don't think I`ll ever need).
I love working with acrylic but acrylic only case wasn't an option since the size it big. Went with aluminium as it`s light and strong, acrylic will find it`s place as top/bottom/inside panels.
Size of the case: 70cm x 60cm x 33cm
Components
i7 5820k
MSI x99 sli plus
16 GB Crucial Ballistix
Nvidia GTX 1080
SuperFlower Leadex 750w gold
Samsung 850 evo 250gb SSD
WD 2tb SSHD
Watercool Heatkiller IV pro acryl
EK gtx1080 acetal block
2x Feser Xchanger 480 rad
Alphacool VPP755 pump with Watercool Heatkiller top
Aquacomputer Aquatube reservoir
Aquacomputer Aquaero 5 LT
8x Enermax Cluster Advance fan
3x AeroCool Dead Silence fan
Onto the project then:
assembled shell(incredibly sturdy while only 6 kg of weight)
cut top/bottom acrylic to size and drilled fan holes
and sanded. was going to paint the panels flat white but frosted effect looks very good, might leave it as is
in the case
and with a rad
I will be using Enermax Cluster fans for both rads but as case fans I wanted something a bit different(for a contrast), chose these as they are very quiet and push reasonable amount of air.
Painted white and sleeved
That's it for now, not much i know and it looks like nothing at this stage but gotta start somewhere.
Next step: motherboard/inside wall panel, holes for fans in front and i/o with pcie slots cutouts.
More pics and update soon.
27/08/17 update
10/09/17 update
28.09.17 update
finished build
for many more pics please go through the whole build log
thank you all for looking, it was a great fun. onto the next project
Originally Posted by Watercool-Jakob View Post
Loved your previous build. I'll keep my eyes on this one for sure, I have a weak spot for DIY cases
Thanks Jakob, these words mean a lot to me. Will, post some updates soon, stay tuned
update
time for front panel fans(3x120mm), going through 4mm aluminium takes a LOT of time(and WD-40)
all three holes done
now looking for some interesting but simple 360 grill, any ideas highly appreciated
Discussion Starter · #6 ·
another small update:
after checking and considering many options for front 360 grill i decided to go with aluminium Aquacomputer grill as it will compose nicely with other aluminium accents in the case. Has got very simple and clean look too. Tried it on with the fans:
Got hold on an amazing deal today and picked a new lens for my camera. Messed with it a bit and took a few shots of hardware
Discussion Starter · #8 ·
case painted and put back together.
quite happy with the result, looks very clean and exposed.
stay tuned for more
Originally Posted by JCArch View Post
Nice and clean looking case, there! I would love to see it in a matte black, but it looks great nonetheless. Looking forward to seeing it completed
I will start another, similar concept, case very soon which is going to be all black(much smaller tho, only matx with 240 rad). Build log should be here too so keep your eyes open
Discussion Starter · #11 ·
test fit of led strips. 2x 50cm 8W each, the whole room got lit up, they generate quite a lot of heat and are too bright. Gotta find something dimmer and narrower beam of light as these spread too wide
Mining the DB
Looking very very clean.
Subbed.
Discussion Starter · #15 ·
update!
received a huge parcel from Alphacool , some very sexy blocks and parts there, I love the fact that every single piece is nicely and securely packed, very excited to start building!
next step: painting
Mining the DB
Those watercooling parts look pretty awesome. Cant wait to see it all going in
Discussion Starter · #19 ·
update
painted GPU block( if anyone wants to do the same and disassemble core block- don't!! The oring gasket thing under the cooling plate is level 25[1-10 scale]), looks very good, sorry for poor light pics, I will shot some more soon in daylight .
I did some sleeving for EPS cable, I must say new Alphacool Alphacord sleeving is very nice and soft in touch, I think i'd prefer it to be matt but let's wait and see how it looks in the case with all lighting.
again, pics don't really show much, very bad light
Discussion Starter · #20 ·
After long debate and extensive reading i decided to go for NB eLoops B12-2. I didn't want PWM versions as many ppl report unpleasant pwm ticking noise when slowed down to low rpm. I am going to voltage regulate these, possibly 6-8V. Still not sure if Aquaero 6 can handle 8 of these without overheating( ca split them into two channels, 4 fans per channel, but does it change anything?). One thing I'm sure about; these are definitely the best looking fans available!
So i got this beauty!!
1 - 20 of 79 Posts
