Hi overclockers!
I would like to show you my work on Silverstone Raven RVZ01 case. I love ITX format. So It was easy decision, which case should I mod. To be honest, I would like to have NCASE M1 (cheers for author), but It is quite expensive to send it into Czech Republic, where I live.
So I bought Raven RVZ01. What I have seen as negative is no space for proper cpu cooler. It was quite blind shot, but I ordered Corsair H100i. It is not supported at all due to size of radiator. Silverstone recommends Corsair H60. Which I had years ago, but it was weak to cool proper OC.
When Raven came to me, it was damaged from factory. Paint under motherboard was scratched. That was another reason, why I should mod it!
So end of essay, below are parts, which will be used in this build:
- Raven RVZ01
- Intel i5 4690k - 4600 MHz
- ASUS Maximus VII Impact
- Cosrair H100i
- Corsair vengeance 2x4gb
- GPU - still changing
- Silverstone ST45SF-G
- Samsung 830 256gb
