Would You Rather...
  • S3 Caselabs
    Votes: 19 19.4%
  • S5 Caselabs
    Votes: 21 21.4%
  • S8 Caselabs
    Votes: 33 33.7%
  • Wayyyy Cheaper Case
    Votes: 7 7.1%
  • What the hell is this
    Votes: 9 9.2%
  • Do I have to Answer?
    Votes: 9 9.2%
1 - 20 of 682 Posts
Ladies, One at a Time
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
This Computer will be to Display at work (And Use of Course
My Facebook Page (Jesters Wicked PC Builds)
I am replacing my ASUS Laptop I purchased in 2009 that has a Centrino 2 and Windows Vista 32bit.
The Goal here is to Create an efficient cooling system with 1 x 240mm Radiator and Overclock the Processor to 4.5Ghz (Keeping temps under 85C) During Realbench 2.4 and at the same time advertising my skills at Work!
Parts List:
Case: Caselabs S3 (Full Windowed: Gunmetal/White Interior) With 240mm Flex Bay Mount (Received)
Processor: I5 4690K (Ordered!)
MotherBoard: Asus Impact VII (Received)
Ram: Kingston 2 x 4gb 1866Mhz Ram (White) Received
GPU: EVGA 780 SC (2784 Model) Received
PSU: EVGA 650 GS Fully Modular! (Received)
Storage: Crucial MX 100 256GB SSD Received/ Seagate1TB HDD 7200 Rpm
Received
Ek GTX 780 Backplate (Red) : Ordered Received
WaterCoolinG
Ordered and Recieved already (Invoice Picture)
Radiator: XSPC 240mm V3 Received and Painted
Reservoir: EK 150mm V3 Multiport (Top and Bottom) White (Received)
DDC Pump/ Top Combo: EK DDC/ DDC Pump Top Combo 3.2 PMW (Original CSQ Clear) (Received)
Drain Valve: Bitspower Deluxe White Drain Valve (Received)
Tubing: 12mm Bitspower Crystal Link (Received)
DDC Heatsink: Bitspower White Received
Processor Block: EK Supremacy EVO Nickle (Polished and Received)
Bitspower Fittings: C47s and C48s with Possible 90Degree (All in Deluxe White)
Bitspower Deluxe White Male/Male Mini : Ordered Ordered
Mayhems Red Pastel Concentrate : Ordered Ordered
Mayhems Aurora 2 Red will be Used in this Build. Compliments of @Mayhem
Will Have Pictures of Parts Soon.
AND AS ALWAYS, HAVE FUN IN THE BUILD LOG!!
Keep the builds coming sub for sure. Are you going to try something different or keeping with the same style as the division. Btw what do you'll think of the e3 gameplay?
Discussion Starter · #11 ·
Originally Posted by batmanwcm View Post
I'm curious, how are you planning to mount the Res/pump? I have a EK DDC X-Res Pump Top paired with a MCP35X.
For my build, I was planning to pair this:
EK Uni-Pump Holder
with this:
EK Uni-Holder for DDC
and mount it to my PE radiator.
The First Link you Used! I will have something similar to that If I decide to mount to the Rad. Great Question.
E3 gameplay had me all riled up! What do you mean "The Same Style"?
Originally Posted by JourneymanMike View Post
TCO,
I'll be in on this one too!
Best of luck!
Mike
PS When are we going to see some performance #'s
I am not to good posting numbers, I like to build!! Thanks for joining again Mike!!
TCO
Same style meaning all fittings or will you be doing more bends. Parrell or serial gpu set up. I'm saving for the s8 or evolv atx right now. I have the money but can't set my mind to what I want to put in it. Plated chrome copper sounds good. Wish I had an matx board or fine one that can handle sli and a sound card
Discussion Starter · #16 ·
I am leaning toward Parallel Gpu Tubing. 75% Fittings, 25% Bends
TCO
1 - 20 of 682 Posts
