This thread is to document and also for some help with my water cooling, this is my 1st water cooled build, although I planned one a long time ago I never got around to it.
I was considering a 343B but I dont think I actually need it or have the budget to make good use of it.
I have decided on the PC-V2120 which I think is perfect for my goal and what I have to work with around my desk.
I am really after the quietest water pump(s) possible.
I am only considering cooling the CPU and GPU, VRM.
Explanation of choices
The planned Hardware:
SSDx2 Intel 520 240GB
Tower Lian Li PC-V2120
CPU 3770k bare die.
Mobo P8Z77-V DELUXE
RAM 2x4GB Dominator GT
Sound Xonar Essence ST using (PCIE to PCI adapter)
PSU Seasonic XP-1000
GFX: Zotac GTX 670
HDDs 3TB x4 Raid10
aquaero 5 LT USB fan and pump controller
Cooling:
Res: Aquabox professional Reservoir
Pump: Aquastream XT Ultra Pump x2
SR1 360, 120, 140
CPU Block: EK-Supreme HF - Acetal+EN (Nickel)
GPU EK-FC680 GTX - Acetal+EN (Nickel)
Tygon 2001!!
Swiftech Lok-seal compression fittings.
Using the ST on the PCI-e board
Overclocking the RAM
Delidding the CPU
HDD Silencing
CPU 3770k bare die.
Mobo P8Z77-V DELUXE
GFX: Zotac GTX 670
HDDs 3TB x4 Raid10
Cooling:
SR1 360, 120, 140
Tygon 2001!!
Delidding the CPU
HDD Silencing
