1 - 20 of 80 Posts
I can remember it perfectly. I was young and stupid at the time, and I wanted to buy an Alienware PC since I was tired of my slow laptop. It was mid-July when I woke up one morning with an idea: "Maybe I could build myself a computer? I'm pretty sure I could come out with something as performant as an Alienware, but cheaper". That's where it all began.
So here I am, one year and a half later, writting this post as my dream is coming to life.
I own you guys a lot, everyone on this forum. You helped me alot when I had question and you helped keeping the flame alive. I also promised a build log to a lot of people!
If you have any questions, don't be afraid, I'll gladly answer them!
Finally, I'd like to mention that english isn't my primary language, so excuse the mistakes!
Corsair Graphite 600TM (with window)
Gigabyte GA-Z68XP-UD3P
Processor
Intel Core i7 2600K
Memory
G.SKILL Ripjaws X 16GB (2 x 4GB) DDR3 1600
Video Card
EVGA GeForce GTX 580 Fermi
Western Digital 2TB Caviar Green SATA2
SSD
Crucial RealSSD C300 128GB
Corsair AX850
Disc Drive
LG GH24LS70 24X SATA Lightscribe
Sound Card
ASUS Xonar DG 5.1
OS
Microsoft Windows 7 64-bit
Fans
3x Cooler Master SickleFlow 120
1x Coolermaster Megaflow 200MM Red LED
Misc
Sunbeam Rheosmart 6 Fan Controller
RGB LED Strip + Controller
Rosewill USB 2.0 External 74-in-1 Card Reader
ASUS Mini USB Bluetooth Dongle
TP-LINK TL-WN722N Wireless Adapter
Razer Carcharias
Logitech Extreme 3D Pro USB Joystick
CPU Block
XSPC RayStorm
VGA Block
EK nVidia 580 GTX VGA Cooling Block - Acetal
Radiator/Pump
XSPC X2O 750 Dual 5.25" Bay Reservoir Pump
Radiators
1x XSPC RS240
1x XSPC RS120
Tubing
PrimoFlex Pro LRT UV Red Tubing - 7/16in. ID X 5/8in. OD
Fittings
Not decided yet
Misc
IC Diamond 7 Carat Thermal Compound
Antimicrobial Silver Strip
Making the Rheosmart Fit
Relocate the HDDs Cages
Make the LED strip more customisable (LED controller)
Cutting the Mesh Under the Fans
Sleeve Everything (maybe?)
07/12 - First Shipment
08/12 - Second Shipment
10/12 - Making the Rheosmart Fit
11/12 - Relocating the HDDs Cages
11/12 - Shipment of Sadness
11/12 - PACKING PEANUTS!
15/12 - Yet Another Shipment
18/12 - It's Alive!
20/12 - Houston, We Have Something Fast Over Here
20/12 - Ohai! Hello little green thing!
20/12 - AAAHHHH! MY EYES! IT'S TOO BRIGHT!!!!!!
06/01 - LED Controller
09/01 - D'oh!
I got my very first shipment on wednesday.
God I love newegg's packaging!
What was inside: my three 120mm fans and my card reader.
Testing the fans on an old 100w power supply.
I gotta say: I like how the fans light up!
Hope you enjoyed! Stay tuned!
Originally Posted by vercomtech View Post
Nice intro! - Looking forward to seeing some updates
Thanks! I appreciate it!
Came home thursday to find this waiting at my door. I gotta say, I was really excited since this one is pretty big!
What was inside: mobo, headset, wireless adapter, fan controller, OS, bluetooth dongle and two HDMI cables:
And let's not forget my limited edition of Battlefield 3!
Can't wait to see this progress, I have the same case and similar specs. You'll love it, there's so much freaking room and amazing cable management!
Subbed
Subbed
Thanks! Cable management is one of the main reasons I chose this case, coming after the look!
Discussion Starter · #8 ·
There is a little flaw with the Rheosmart (not sure if it's only mine): this screw, which holds the front panel, makes contact with the little notch inside the drive bays (as you'll see in the next picture).
This causes the the controller to not sit properly in the case, making it impossible to screw in place (it's not long enough to be used with the toolless mechanism). I tried, with the help of my dad, modifying the screw, like so:
But that didn't work. Next thing I tried: making a little notch where the screw could sit properly:
And voilà! (Sorry for the blurry pic)
I also got rid of the extensions that connects to the original fan controller:
And used the spare room to route the ones that goes to the Rheosmart. I don't want to see them (they're pretty ugly) so this was perfect.
That was the very first thing I did with my 600T
Are you planning on sleeving the cables that go to your Rheosmart?
This one might or might not be considered as a mod to some people. I kinda consider it as one, since I saw some people ask how to remove the base under the cages.
When you remove the two cages, you're left with this plastic base right here:
To get rid of it, you have to remove these four screws (I already removed two of them in the picture):
There ya go! The front of your case is now clear!
P.S. Now that I've posted all the work I did so far, updates will come as they happen.
Discussion Starter · #11 ·
Depends on how much money I still have when everything is done. I already blew my budget by 700$ and I didn't order the water cooling parts yet!
I contacted Lutro0 to get some custom extensions, but it was just too expensive.
Nice build
I have the same Sunbeam controller (and the same case, the T-M version though) and didn't notice the screw interfering with installation. Odd though as they must have changed the design since I got mine
Discussion Starter · #13 ·
Originally Posted by Robilar View Post
Nice build
I'm pretty sure the problem came from the controller I got. I just didn't feel like sending it to RMA.
I saw your build in the clubs' thread. That's a nice machine you got there!
Nice work on fixing the issue, but I would have just looked for a countersunk screw that would fit in it's place. Have no idea if it would work though.
Discussion Starter · #15 ·
That's exactly what we did when we modified the screw. We couldn't find any that weren't too long and the local hardware store was closed, so we had to go with what we had!
Discussion Starter · #17 ·
Originally Posted by kevingreenbmx View Post
looks like you will have a nice build
I'll be watching
Thanks!
Subscribed. Love the layout of the thread!
Discussion Starter · #19 ·
Thanks! Glad you enjoy!
Discussion Starter · #20 ·
Small update: I expect to receive most of my missing parts tomorrow and my GTX 580 wednesday. Sadly, I won't be able to use any of this since I'll only get my power supply at the end of the week, IF I'm lucky!
My case's window is still BO and I don't know anything about my LED strips, except that they are shipped.
Expect some updates soon!
1 - 20 of 80 Posts
