1 - 8 of 8 Posts
Hey Folks,
Another Weekend and another build is being cooked. This time, it's a pre-order with a blue theme colour and as flashy as possible (Make anyone that looks at this beast say HOLLY F***)
so Colour Scheme is going to be Blue and black, of course matching the motherboard/case and sleeving. No Water cooling here (less painting to do).
Hope you'll enjoy it.
HAF X (Going to be modded to match the theme and may I add, DAMN that's what I call a case)
Components
- CPU: Intel i5 - 3550s
- Motherboard: Asus Z77
- Ram: Corsair Vengeance 8GB 1600MHz
- SSD: Intel XM-25 80GB
- HDD: WD Purple 1TB x 2 in RAID 0
- PSU: Corsair CX750M
- GPU: EVGA GTX 760 2GB
- BitFenix Spectre Pro Fans (One of the best looking / performance fans in my opinion)
- Cooler Master V8 CPU cooler (cuz it just looks bad ass)
Sleeving
- MDP-X Black
- Still deciding on the blue
Extra
- Sound activated cathodes and / or LEDs
Everything is subject to change. I'll update along the way.
This weekends work:
A bit Dusty
The Goodies
Let's skip ahead and go outside
Let's fix that red box
Now that the box is blue, let's put some stuff on it
Oh yeah, now it's I see it, blue!
We can't put new stuff on old dusty stuff, can we now?
Case, meet air compressor, air compressor, meet case
Now that painting and cleaning is done, let's go inside and check what the case looks like
Looks good, but how about we add some blue to that
Soooo the fan is completely black?
Nope, let's make it a real fan
Did someone say blue?
Oh wait, blue? Did you say blue?
I thought you said no more painting!
Lies, lies everywhere
Well then, if you're going to lie, might as well go all out
Again...
aaaaaaaaaaand the final result ?
No More circles of dust
That's one heck of a rear
And the board goes in
Everyboard needs a CPU
Plastic bags ripped and Hard drives out
Dat Damn heat spreader
Better than an engine of a car
Old trusty friend
Stock? Did someone say stock fans...
Dat Design
That's it folks, till next week, or sometime this week if time permits
ah it's been a while since I've updated the thread, it's complete, definitely needs more pics, will be coming soon.
For now here's the sleeving, all 100m of it
Some Blue to match the theme
Some cables, do you know why I'm sleeving those?
So, they're sleeved, why?
I'll give you a hint, this looks AWFUL
How about now
Sleeved some extensions, didn't take much time, about 8 hours in total
Yup, didn't take any time
This Cooler looks bad ass
So, as suggested above, stuff needs painting, it wasn't the ram or the GPU but
So now you know, that got painted, here's the whole bunch, Before
And after
PSU shroud, Spoiler, coming soon a full plexi custom made one
oh Yeah, the 24 pin cable, the mean bad ass of the machine
The 8 pin cable, I can't really take good pics with this camera yet :S
So my friend wanted something flashy, needed some custom cables for that
Cable has been measured, crimped and attached
Tested that cable, a quick and dirty shot
Yeah, it needs another one
Did I mention that something else got painted?
So, how does it look ?
Enough inside pics, problem is, sun is almost down :/
Does anyone notice that both back side panels are blue ?
Side On
Needs more plexi
Side Off
Blue blue blue
Discussion Starter · #8 ·
Originally Posted by Sora1421 View Post
Amazing work. Very tasteful with the painting! I hope she serves you well over the years to come and a lot of fantastic games are played on it
Thank you for the kind words sir
1 - 8 of 8 Posts
