Yeah I think it will definitely look better - plus after all of the machinations I've gone through thus far in this build - once I get it all back together finally... if I get 'the itch' again in the next year or so - that will be directed at a different build. I'm sick of not having a computer that's easily accessable (had to temporarily shelve my iMac just to have more working room at chair level because doing everything hunched over on the floor was doing a number on my back). Sucks getting old.
Welcome aboard! Yeah, the tubing runs aren't as straightforward as one might like in this case. That's one of the main problems that precipitate my decision to go ahead with the pedestal. Once I had the UT60s on the PSU side I discovered that a rad on the bottom (at least in push-pull configuration) couldn't have the tubing running through the lower grommeted hole in the case. I could have left the left-most pull fan off and made it with 3 fittings (90+extension+90) or drilled for a passthrough bung - but that would have been in a very thin place on the divider plate.
Welcome aboard for the second go-around! Also... love the avatar...
Actually, he's currently back in Pahrump. His "No Compete" is up... and he's looking for an appropriate gig. I am impatiently waiting. Remember "Art's Parts"?Originally Posted by DiGiCiDAL
On a related, and totally off-topic note, KNYE and his house in Pahrump is right next door to my wife's uncle's property out there. I could never find his house until I realized I could just drive towards that trailer with the 90ft antenna in the back yard! LOL! Of course now I think he's in the Philippines...
Yep, it sure is! I really think the UT60 is pretty much the sweet spot between absolute performance and practically useful. The XT45 (I've got one of those too in this build) is on the other side. Any smaller (like the 25-30mm rads) and you either need many of them, or you're not going to be beating good air cooling by much. You'll still do a little better, but that's why I don't care for the CLC's for the most part. You need a really high FPI to make it useable. I'd much rather have a high-flowing (both air and water) rad that's thicker.
I'll be going with just push on the XTs in the base. I don't think I will have enough room to do push-pull... will have to check again on how B-Neg did his. I know he used XSPC rads but if they are the same thickness and he did push-pull, then I can do it too. I will be using another XT45 in push pull on the top though, so 1,440MM of cooling space! Super excited!Originally Posted by DiGiCiDAL
But the guys running Monstas...![]()
OK, I admit it looks cool and (provided you run your fans fast enough) can offload some impressive wattage into the air... but with 25mm thick fans you're talking about 13cm (so just over 5 inches) for a single rad if you run it push pull. I could pull that off in this pedestal, but then there would only be about 3.5" clearance in between them! And the weight would be substantial as well.
In your LD are you going to be running the XT45s as push-pull or push only? I'm looking forward to seeing everything going in there.![]()
I think it should work, but it will be very tight I'm sure. If you figure 96mm for fan+rad+fan and another 1mm for mounting bracket... times 2 you're still under 200mm and the case is 220mm wide (so you should have a little over an inch between the two). You definitely aren't putting anything else in there, but you would still have enough space for tubing runs to go between them. The downside, sort of, is that you'd definitely have to run directional flow because there isn't enough space between to feed them well (or exhaust if reversed) for all cold intakes. Of course, with the extra amount of cooling capacity you'll have... that's not much of an issue.Originally Posted by Jeffinslaw
I'll be going with just push on the XTs in the base. I don't think I will have enough room to do push-pull... will have to check again on how B-Neg did his. I know he used XSPC rads but if they are the same thickness and he did push-pull, then I can do it too. I will be using another XT45 in push pull on the top though, so 1,440MM of cooling space! Super excited!![]()
Jeffinslaw
That last option was what I was going to do. I plan to have all of the rads intake and all of the case fans as exhaust. That way, both rads in the bottom will be pulling in cold air. So if by going just push, and then having the air exhausted by the fan at the front of the case, it should have some good temps, I will for sure test it and find out which one works best.Originally Posted by DiGiCiDAL
The other aspect of the XT45's is they are actually not helped much by push-pull if you're running fans that are at least 1000RPM or higher on them. You'd probably get better performance running 1 set of fans per rad and having both rads pulling cold air in opposing directions. You'll have to test it to see for sure but that would be my guess.
I'm kind of changing my thinking on this one - and I think I'll be doing the same on mine. I might do a straight through design however. Now that my case will no longer fit under a desk (with pedestal and casters it will be ~31" tall) I'm thinking of rearranging my office and doing a "hybrid sandwich" for the pedestal - I'm coining that term now!Originally Posted by Jeffinslaw
Jeffinslaw
Welcome aboard. Yeah, I'm kind of under the radar... but at least with the first incarnation that made sense because it's a ninja-build.
IKR? I almost wish I'd gone with Monstas now that I can see the room... I could have run 2 push pull and still fit tubing runs between, but this way will be much, much easier to work with easily... and I might just stick my pump down there instead of up top... and just hope it never has problems until I'm ready to do a serious upgrade cycle.
