Hello guys (and gals) and welcome to my build log my desired dream pc build!
Ironically I started planning out the part list by going more realistic and economical (hence the name "modesty"). But ever since I got promoted at my job I been given way more work than I am used to. So with the extra money I been making plus the extra stress that came with it I decided, "F**k it! I'm going to treat myself! I'm going all out!" And thus this build became the beast as it is now. Kept the name though.
Hardwares
Cooling Components
Hardwares
- CPU - Intel i7-8700K (Purchased)
- MOTHERBOARD - MSI z370 Gaming Pro Carbon AC (Purchased)
- GPU - 2x Nvidia Geforce GTX 1080 Ti FE (Purchased)
- Memory - G.Skill Trident Z RGB 2x8gb 3200mhz (Purchased)
- STORAGE - Crucial MX300 1tb (Purchased), Crucial BX100 500gb (Purchased), Samsung 960 EVO 500gb (Purchased), Western Digital Black 4tb (Purchased)
- PSU - SeaSonic PRIME 1200w Platinum (Purchased)
- Case - Fractal Design Definse S w/ Window (Purchased) Modding with custom tempered glass side panel
Cooling Components
- EK Supremacy EVO Nickel (Clear) (Purchased)
- EK GTX FE waterblocks and backplates (Purchased)
- EK CoolStream PE & SE 360 (Purchased)
- EK XRES 100 Revo D5 w/ RES X3 250 (Purchased)
- EK CryoFuel Coolant (Clear) (Purchased)
- Various EK fittings (Purchased)
- 3x Corsair ML Pro 120m White LED (Purchased)
- 3x EK Vardar F4-120 2200 rpm (Purchased)
- Numerous 12mm Tubes (Purchased)
- DarkSide 3-way PWM Fan Splitter (Purchased)
- 4x CableMod Sata 3 Cable (Black) (Purchased)
- PrimoChill Rigid Tubing Finishing Bit (Purchased)
- ZOTAC SLI BRIDGE (Purchased)
- Ensourced Custom Sleeved Cables
- Custom Tempered Glass (Purchased)
