This will be a rebuild of my current PC "The One". The PC was initially housed in Corsair Graphite 760T before moving everything to the Caselabs Mercury S8. My hope is to finish this build as quick as possible as I need a PC to do my application development. My laptop feels very sluggish, thus working on it isn't fun at all. Considering most of the stuff I do are data related, I need the PC up running asap.
PC Components
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor
Motherboard: Asus Rampage V Edition 10 EATX LGA2011-3 Motherboard
Memory: G.Skill Ripjaws 4 series 32GB (4 x 8GB) DDR4-2800 Memory
Storage: Crucial MX100 512GB 2.5" Solid State Drive
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive
Video Card: EVGA EVGA GTX 980 Ti Hydro Copper
Power Supply: EVGA SuperNOVA P2 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit
Case: Caselabs Mercury S8
Keyboard: Logitech G710 Plus Wired Gaming Keyboard
Mouse: Corsair M65 PRO RGB FPS Wired Optical Mouse
WC Components: EK-Supremacy EVO CPU Water Block (Nickel/Acetal)
WC Components: Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
WC Components: Black Ice Nemesis 36 0GTS x 2
WC Components: EK-RAM Monarch X4 - Acetal+Nickel
WC Components: EK-RAM Monarch Module - Black (4pcs)
WC Components: EK-D5 Dual TOP G1/4 CSQ - Acetal
WC Components: Aqua Compu ter Aquaer o 6 LT
WC Components: Aquacomputer Aquaero 6 Pro / XT Passive Heatsink | Black
WC Components: Aquacomputer Flow Rate Sensor MPS Flow 400 G1/4
WC Components: Aquacomputer D5 pump mechnics with USB- and aquabus interface x 2
WC Components: Aqua Computer Farbwerk RGB LED Controller
WC Components: Bitspower X-Station Power-Extension I - Male Version - UV
WC Components: Bitspower G1/4" Silver Shining Enhance Multi-Link For Acrylic Tube OD 12MM
WC Components: Bitspower BP-WTP-C48 G1/4" Silver Shining Multi-Link Adapter
WC Components: Bitspower BP-MVV-SLBK Mini-Valve - Silver Shining With Black Handle )
WC Components: Bitspower G1/4 Silver Shiny Dual Rotary 90 Compression Fitting-ID 3/8" OD 5/8"
WC Components: Bitspower Premium G1/4" Shiny Silver High Flow 3/8" (5/8") Compression Fitting
WC Components: Bitspower G 1/4" Silver Shiny Rotary 90 Degree IG 1/4" Adapter
WC Components: Bitspower G1/4" Silver Shining Male to Male Rotary Adapter
WC Components: Bitspower Rotary Fitting "Q" Adapter (Purchased For $9.99)
WC Components: Bitspower BP-WTP-C60 G1/4" Silver Shining IG1/4" Extender - 15mm
WC Components: Bitspower G1/4" Silver Shining Angle 3/8" Fitting
WC Components: Bitspower BP-WTP-C63 G1/4" Silver Shining IG1/4" Extender - 30mm
WC Components: Bitspower Mini Dual G1/4" High Flow Fitting - Shiny Silver Finish
WC Components: Bitspower Case Top Water Fill/ Through Hole Fitting Set - Shiny Silver Finish
WC Components: BarrowG 1/4" Silver Shiny Temperature Sensor Stop Fitting
WC Components: Bitspower Silver Shining Enhance 90-Degree Dual Multi-Link Adapter
WC Components: Bitspower None Chamfer Brass Link Tubing OD12MM Shining Silver
WC Components: Bitspower Silver Shining Enhance Rotary 90-Degree Multi-Link Adapter
WC Components: Bitspower Silver Shining 90-Degree With Dual Inner G1/4" Extender
WC Components: Bitspower Metal Tubing Cutter
WC Components: Monsoon MMRS 100mm Tension Rods - Red
WC Components: Monsoon MMRS Acrylic Tube 100mm - Blood Red
WC Components: Monsoon MMRS D5 Motor Mounting Tube - Matte Black
WC Components: Monsoon MMRS Triple Port End Cap - Black
WC Components: Monsoon MMRS End Cap with D5 Pump Mount - Black.
WC Components: Monsoon Premium G 1 / 4 Plug - Red
WC Components: Clear UV-Reactive Tubing - 3/8in. ID X 5/8in. OD - 13 FT
Other: Black ICE Cable Combs double pack
Other: Caselabs Dust Filter from DEMCifilter
PC Components
