1 - 20 of 45 Posts
Hey Folks,
It's been a loooooooooong time since I've built a rig that requires more than a weekend worth of work, finally it's time to get back on track before the snow hits.
so Color Scheme is going to be Yellow and black, of course matching the motherboard/case, sleeving and water-cooling equipment
Hope you'll enjoy it.
Corsair C70 Gunmetal (Going to be modded to match the theme)
Components
- CPU: Intel i5 - 4670K
- Motherboard: BIOSTAR Hi-Fi Z97WE
- Ram: un-decided
- HDD: Seagate Pipeline 2TB (might run two of them in RAID 0)
- PSU: EVGA 600W B
- GPU: Zotac GTX 680 4GB edition
- XSPC Raystorm waterblock (People's favorite)
- Black Ice GT 360 Radiator (broke) + Alphacool NexXxoS ST30 + Swiftech MCR220-QP-K
- XSPC X2O 750 V4 Dual Bay Res/Pump
- Bitspower 1/2ID 3/4OD silver fittings
- Primochill 1/2ID 3/4OD clear tubing
- Distilled water with Mayhems yellow dye and Mayhems Biocide Extreme
Sleeving
- MDP-X Black
- Axon banana yellow
Everything is subject to change. I'll update along the way.
Fans and bays are out!
I love how these bays are easily taken out
First of all, measurements measurements measurements and guess what, something won't let my 360 go in!
Problem easily fixed
Sure enough, 2 minutes later
Piece is gone!
Time to put the rad inside and guess what happened
Here, I'll zoom in, yes I'm f***ing pissed
A shot of the CPU
PSU
HDD
The GPU
4GB
Can't have a 4GB card with no block
Cuz colored tubing is too mainstream
The most common block out there
Now for the most expensive items of this build
Discussion Starter · #8 ·
Got the stuff ready for painting
Painted the parts over two days and threw them in the case, couldn't take pics of the process as it was freaken 4 degrees!!
Oh yeah, the board is mounted
A proper pic of the CPU
Dat chipset
did I mention that I got the Bay res/rad
This case doesn't like water cooling!! Can't fit the res unless I get the appliers
Seems like it will have to remain like this till tomorrow ...
Originally Posted by JockThatCamel View Post
Surprised how good that board looks in that case.
Cheers
If I knew how to take pictures with this camera, it would've looked much much better, seems like it's going to require a full semester just to learn the full options and capabilities of this DSLR camera lol
Discussion Starter · #11 ·
A small update, got home today and guess what, I could feel the sun!! No clouds!!
looked at that pc and well, it was time to pimp it up
Looked at that PSU
yea, that has to be fixed, How can I fix that? Here's a hint.
Yeah, the front is too plain, don't you think?
well, if I'm painting, I might as well make it more than one item
Not taking the camera outside, so let's forward to 40 mins later
Front goes in and awesome comes out
Did I mention that I bent some metal, fit that res and attached that front?
How about we throw that modified PSU in there
Crappy picture, I know, It's 11:30pm and I've been awake since 7am, just wanted to share that last piece done today
Here's a close up
Discussion Starter · #13 ·
Originally Posted by MrFumbles91 View Post
Are you able to return that pump? I would suggest it if possible just because of alot of bad experience with mine
nope, can't return it. It's the second time I use that pump and I've had no problems last time I used it. What problems did you have ?
Discussion Starter · #15 ·
Its not just me, there are videos on youtube of people experiencing a loud humming like sound. I've never had performance issues with the pump, just annoyance issues.
I'll be switching over to the D5 Bay res eventually.
Either way, subbed.
oh yeah, I know what you mean, pc was under the desk on the first build and I usually game with headphones on or surround sound and there's always something playing (game - show - movie - music) as I can't work if its dead silent so it didn't really bother me.
Thanks for the sub
Discussion Starter · #17 ·
What tubing are you using? Something yellow I'd assume.
I've seen either Bitspower or Swiftech or someone lol has back and yellow compression fittings that would look nice
tubing is clear 3/4 primochill with distilled water and mayhems yellow dye
Mmm paint the fittings, I sense a busy weekend (if the weather is good for painting )
1 - 20 of 45 Posts
