Just pour a little on and let it soak a little perhaps.Originally Posted by Jakewat
Well I'm really having no luck with this logo removal. I picked up some 100% acetone, and still did nothing. So I've been at it with med-fine grit sand paper combined with acetone and yet this is the horrible result so far. I don't want to sand too much in case I end up damaging the case coating. I feel as though I've got some special "impossible to remove" paint on my case. I also didn't want to pick up paint stipper as it only comes in large containers.
http://s1354.photobucket.com/user/Jakewat97/media/temporary_zpsabd662b4.jpg.html![]()
The big opening is just to get to the cpu block mount from behind, if you look at the pics of my motherboard tray (before I put the acrylic over it) I had cut two rectangles which were enough to fit my 24pin through one, and then sata and 2x 6pins through the other. If you are going to running SLI you may want bigger holes or to better plan the layout. Truthfully, my original cuts were a little rushed and not thoroughly thought out, if you have a look at something like coldzero's cuts in their custom tray it will give you an idea for how you want your own to look. hope that helped.
Who told you that? I don't see how is would cause any problems as it's no different to the design of a simple waterblock. I just like the idea as it cleans up a few of the runs and does away with the need for fill port fittingsOriginally Posted by natsu2014
Yeah CZ layout is something I'm considering as well. I'm not into SLI anymore, for CSGO my trusty 670 is more than enough![]()
I wanted to do the same thing with water channels but was told that is only for showcase and it's very problematic for long time usage. Although I find great looking
Would you be interested in a similar purple to what I used in my ft03 build? Still have all the coolant if you want itOriginally Posted by Jakewat
Yea, I'm having a hard time deciding on the colour still. I was about to go for ice white, but a purple could still be a possibility. But after having a look there is no premade colour that I like. What kind of coolants could I mix to achieve the right purple, would like it to be a darker purple but not a blue purple.
