I finally decided to sit down and do a log on this build. I am over halfway through the build already... but started taking some pics the last time I had it totally stripped down after initial fitting. I wanted to build something that would have some power, watercooled, quiet and not be overly huge. I almost went with a Caselabs Magnum 10... then found the Lian Li D600. Smaller... but I thought it would work. It is tighter than the Caselabs would have been, for sure. But everything is fitting like I wanted (after a few redesigns and component changes. I wanted to use the Acrylic Rad Grills that Primochill makes to give it a different look, and am mounting the "Pull" radiator fans on the outside of the case (mostly due to lack of room, but I like the way it looks also.) Black and Red theme... and some lighting.
Hope to hear some comments... and any advice is welcome!
Component:s:
Case - Lian Li PC-D600
CPU - Intel Core i7-4770K 3.5GHz LGA 1150 Quad-Core Desktop Processor
Motherboard - ASUS MAXIMUS VI EXTREME ATX Intel Motherboard
Graphics - EVGA GeForce GTX 780 Ti x3
RAM - Kingston HyperX Beast 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)...
Hard Drive - Western Digital RE 2TB 3.5"" SAS 6Gb/s Enterprise Internal Hard Drive X2 (Backups and general storage)
Hard Drive - Samsung 840 PRO Series MZ-7PD256 256GB 2.5-inch SSD X4 (probably in Raid 0) (Boot and games)
Optical Drive - Pawtec External USB 3.0 Aluminum 8X DVD-RW Writer Optical Drive with Lightscribe (Black)
Cooling - Monsoon Series Two Dual Bay Reservoir w/ Quick Change LED Control - Matte Black w/ Red Trim
Cooling - Swifttech MCP50x/2 (when they are released)
Cooling - Primochill rigid acrylic tubing
Cooling - EK Waterblocks EK-Supremacy Nickel CPU Water Block
Cooling - EK 780Ti waterblocks x3 - Nickel
Cooling - Primochill Revolver Rigid Compression Fittings
Cooling - Primochill Acrylic Radiator Grills - Red and Black - Various sizes - X9
Cooling - Alphacool ST30 280 radiator x2
Cooling - Alphacool 420 80mm x1
Cooling - Primochill Vortex Flow Indicator
Fan Controller - Lamptron Fan Controller 50w x 4 Channel FC9 (modded to restrict minimum RPM to about 500 RPM... can no longer turn fans OFF!
Fans - Rosewill Hyperborea 140mm Fans x14 - For radiators - SP 2.76 - CFM 89
Fans - AeroCool Shark 140mm Fan x1 for some extra air cooling on the Mobo
Fans - AeroCool Shark 120mm Fans x3 - rear case, and HHD bays
Power - EVGA SuperNOVA NEX1500 Classified 120-PG-1500-VR 1500W Power Supply
OS - Microsoft Windows 7 Ultimate
Monitor - Dell U3014 30" LED Backlight LED Monitor IPS panel
Keyboard - Steelseries Merc Stealth Black Wired Gaming Keyboard
Mouse - Razer Deathader 2013
Mouse Pad - Razer Scarab Expert Hard Gaming Mouse Mat
Audio - Logitech X-540 5.1 speakers with sub
Component:s:
