hey guys ive decided to build myself a new rig for the new year. this is going to be a fully water cooled matx build inside the silverstone ps07 case. its primary uses are folding , 3d design, recording music, gaming and movies.
this will be a Norse Valkyrie themed build. the side and top panel will have some custom painted decals as well as i will be hand painting runes in specific locations. currently i am debating on hand painting a Thors hammer on the front bezel were the door for the front fans is or if i want to do a small Valkyrie there instead. this build will probably be slow to update after the first few days as hand painting the decals will take some time.
parts list
cpu = intel i7 2600k (donor cpu from my slayer rig)
mobo = asrock z77 professional - m
ram = patriot viper extreme division 4 ddr3 1866 cl9 16gb kit
gpu = evga gtx 670 2gb reference card
psu = corsair ax850
ssd = ocz vertex 4 128gb sata 3
hdd 1 = seagate momentus 250gb sata 3 2.5" laptop drive
hdd 2 = wd caviar green 2tb sata 3 3.5" desktop drive
cpu block = xspc rasa (donor from slayer rig) - to be modified
gpu block = ek fc670 gtx acetyl csq
rads = 3x xspx ex120 radiators
fans 3x yate loon 1600 rpm 12v fans
silverstone fan controller.
jingway 12v ddc pro 800/lph pump
swiftech microres
primochill white 3/8th white tubing
heres pics of some of the parts
heres what i have so far so that i can test all the hardware before i get started.
cpu installed in the motherboard
installed cooler master n520 (spare heat sink i had laying around)
initial hard drive set up and cable management
heres my current set up until i finish the modifications and customizations of some of the parts.
now that that's all done and every thing works now i can start the fun stuff.
for starters im going to be modding my rasa block, repainting the mounting hardware, mounting plate and back plate.
lapping the copper block contact surface.
gota clean the crud out of the block and fit some new orings.
all finished and nice and shiny.
hahaha the aftermath
started repainting the mounting plate. baking each coat of paint at 300f for aprox 1 hour and yes that is a pie plate left over from xmas.
same thing with the back plate and all the mounting hardware.
all mounting hardware finished and added 2mm washers so that the tension on the cpu block is optimal.
it took alot of testing with my old sig rig to get this down perfectly.
the finished product all reassembled.
now to start work on the rads.
start prepping for paint
the rads are currently in the baking process as i started typing this up. also i got a new camera today and the battery is fully charged now so excuse the crappy cellphone pics the rest will be alot better. i will have another update tonight as soon as the rads are done.
parts list
psu = corsair ax850
swiftech microres
