you will need to make sure you set pfsense to boot straight away upon ESXI starting up and set ESXI to be static IP as it obviously wont get an IP until the pfsense system is booted
i am not sure how well that will work, effectively you are using unraid to make a network accessible datastore? so unraid system will have to boot before everything else (before pfsense) then boot the others up afterwards once the unraid datastores are available.
I'm not sure what do you mean here. If you are referring to unraid on pendrive, I'll probably end up doing a workaround so it ends up as all the VMs on the drive, though the pendrive will still be required in the system. Actually it is pretty unlikely that it will kill the drive since it basically reads it when starting up and saves the settings when some setting changes and that's all the usage it does. If you are referring to all the VMs being stored on a single drive with no redundancy, I'll be running regular backups of them to the unraid array.
The board does support ECC ram, only that they didn't update the memory support list. Hopefully it will work, if not I can return it anyway.
Well ESXI needs to be able to store the files ie the virtual drives and such somewhere in the datastore which is where the OS and such will be installedOriginally Posted by Aximous
ESXI 5.1 i am assuming? though free version seems to max out at 8 cores per VM though when i "removed" the license key to test things it seemed to revert back to a 60 day trialOriginally Posted by Aximous
48 hour stress testing passed, everything is rock stable, temps are nice and cool, I'm pretty satisfied by the results, temps never exceeded 60°C even with 23°C room temps and it stayed pretty silent too.![]()
Next up will be ESXi setup, although I probably won't be able to work on this in the next 2 weeks because of my examsExpect frequent updates after that, I'll probably be working on this or I'll be pretty damn hungover.![]()
