1 - 20 of 104 Posts
COMPONENTS LIST:
  • 7x GTX 980 ti, EVGA Superclocked
  • Asus X99 E-WS 3.1
  • Intel core i7 5930k
  • 32GB DDR4 (2x16GB)
  • Corsair 900D
  • 1TB SSD, Crucial MX200
  • EVGA Supernova T2 1600W
WATERCOOLING:
  • Waterblocks: Aquacomputer copper
  • Radiators: 2x480, 2x240 coolgate + DemciFlex
  • Fans: 18x EK Vardar F4 2200
  • Splitters: Phobya 8x PWM
  • Cables: Aquacomputer
  • Controller: Aquaero 6 Pro
  • Reservoir: Barrow quartz glass with metal caps
  • Fittings: Barrow black, about 50.
  • Pressure equalizer: Barrow
  • Valve: EK
  • Tubing: EK ZMT 10/16
  • Pumps: Dual D5 EK
Let's get started. A small teaser for beginning.
Enjoy!
I take it this isn't for gaming???
RIP OCN 2018
Ooooh, sub'd
Originally Posted by ltpdttcdft View Post
Are you cutting off the second DVI slot?
If smicha owns EVGA 980Ti Kingpin it's one slot card (with waterblock) so cutting ports is not required.
but is it possible, plausible, savable, workable and all other kind of ables.
Hoooly shiit m8!
I definitely subscribed this thread and im also excited to see what kind of POWERsupply system u ended up using bacause i calculated that those beasts will draw over 2 000W if overclocked.
Overclocker
7 980tis? Yeah gonna have to sub for whatever craziness this is.
Are you using one of the Z10PE-D8-WS boards or a variant? That's what I had for my (7) 970's. Same purpose Octane.
I like the approach of making them single slot way better than the Mountain Mods Extended Gold Digger case I bought last year. I ultimately canned this entire project after the 970 slow upper memory fiasco broke. Needless to say I was pissed after buying water blocks etc and a million fans for this rig. I ended up doing a rebound and CaseLabs & two Titan-X SLI but I remember the dream of what I almost did...
:helpingha
Discussion Starter #17
The world record awaits, you know you wanna lol
Yes - I am cutting 6 DVI slots, the 7th gpu - only bracket. The fastest scores for Octane are from Tutor and Notiousweb (Octane forum guys) but these are on more than 7 gpu
Anyway I reached almost 1000, on a single psu and all watercooled in a single case - details soon
Discussion Starter #18
x99 e ws 3.1 - but with some very important bios settings - I'll report it all soon. Asus must update their bios asap.
Discussion Starter #19
Yes - possible
And it works, and saves tons of money by adding only 3 gpus - no need for network rendering, no need for extra licences, mobos, cpu, psu, ram, hdd, ssd,... Overall extra cost is just +3 gpus with waterblocks and two extra 240 rads (+2k EUR net) - I'll talk about details soon.
1 - 20 of 104 Posts
