So the itch has hit me again and its time to revamp my rig! This is my first build log here (sorry it is starting a little late!) and I'm still fairly new to the pc building world but I've been hooked for a bit over a year now. I've rebuilt my loop several times since the first time about 6 months ago and just can't get enough of it! I've spent a overwhelming amount of time reading and learning since then and everyone here has been an awesome inspiration and a huge help! This will be my first time building in a "small" case so I've only got a few changes from my mid-atx case ways. New mobo, ram, and some fittings have all been ordered so things should move along quickly. Sorry this is a pretty long first post since I have already begun working on it, there is plenty more to do still!
Components
CASE- White Corsair Carbide 240- NEW
MOBO- ASUS Z97 Gryphon M-ATX armor edition- NEW
RAM- Klevv Neo 4x4gb 2144mhz CL10- NEW
CPU- 4790k- REUSED. Usually running 4.8ghz at 1.33v, which isn't great but it does fine
GPU- 2x GTX 980- REUSED. Running 1500 core and 8100 memory 24/7 without a hiccup.
PSU- Antec HCG 750M REUSED
STORAGE- SSD-2x 240gb Intel 535, 1x 120gb SP SSD
HDD 1x 1TB WD blue, 3TB Seagate Barracuda
Watercooling>> Pretty much reusing everything that I've got on hand besides a few female-female 90° and a some other fittings. I've also got a hwlabs 360mm I have thought about getting in there but it doesn't fit as nicely as I thought it would and I think I'm doing ok on rad space! Let me know what you think
Radiators:
2x Alphacool UT60 120mm
1x EK xtx 240mm
1x XSPC AX 240mm
1x XSPC EX 280mm
I believe I'll have all of the rads running in push pull but maybe not the AX240 since its rather thin.
Blocks: CPU-EK supremacy mx (EVO plexi top)
GPU-2x Aquacomputer Kryographics copper full cover blocks (1 Stainless Steel, 1 Plexi top)
Pumps: 2x D5 vario in a XSPC bay res
Fittings & Tubing: 14mm XSPC Hardline compression fittings-Black Nickel
14mm XSPC PETG tubing
14mm Bitspower PETG tubing
Reserviors: 2x Phobya Balancer- 1x150, 1x250 Black Nickel
Here is a shot of my build as it is, which should give you a decent idea of most of the watercooling components
Outline
Before I get going on what has happened on the build so far, lets take a look at the general idea. I believe I'll be doing something more like the second photo as far as res configuration.
Ovbiously everything will be a little different, the case orientation will run all of my cables through the table and there are multiple reservoirs. Since it is just for show, I may drop the 200mm res depending on how things fit and what it does to my flow but I think the twin D5's should take care of it. The 2 res's will be connected with ZMT behind the mobo tray
Some parts are here!
Last week I ordered an Asus z97 Gryphon M-ATX mobo, I could only find the non-armor verson at a reasonable price but thankfully I found a decently priced armor kit so I got both. Then imagine my surprise when a fully armored Gryphon shows up at my door! Now I can return the armor kit and sleep better at night because I didn't spend over 200$ on a mobo
At this point I'm getting pretty excited, my deliveries are working out wonderfully! Whats next?
Let's put em together and see how they look!
I've decided to use a table that I already have around the house since its a decent size, fits most of my criteria and is free
It doesn't look perfect but I can look past a few imperfections if I can't fix or hide them.
The Table
I've made all of my rough cuts for the rads and the pc connections. The 2x 240mm rads will be next to each other and the 2x 120 will be one over the other with the top connections bridging the two. The 280mm will be in the top of the table with a black grill over it. There will be 8x 140mm fans running intake somewhere around 1000rpm. And Finally there will be a XSPC dual D5 bay res/pump combo will be fit through the side and there will be a fillport that runs to a bulkhead in the hole above. I've already made some trim pieces for the table res and the fill port although I think I will make my res piece a little bigger to cover the table damage.
Definitely going to have to work on a better filter method! Perhaps another trim piece
However I'm happy with the fan frames for my intake fans. Not perfect but they'll be hidden away
Noctua paintjob!
AAAAAND that is it for tonight! This took a lot longer than I thought it would to write up! Tomorrow I will be draining my current pc and giving everything a cleaning so that I can begin fitting components and seeing how many things actually line up how I think they will
Thanks for reading, I'd love to hear your thoughts!
Components
Radiators:
1x EK xtx 240mm
1x XSPC AX 240mm
1x XSPC EX 280mm
Outline
The Table
Noctua paintjob!
