Little update for filling.
As I don't want air being trapped in the loop once closed I will put a funnel on top and have it run for a couple of days the funnel being filled with coolant coverd by a plastic sheet to prevent dust getting in.
After those few days of running I will remove the coolant from the funnel then I will remove the funnel and fill the T-port to the top so there is really no air.
After that I will put on a g1/4 connection piece female which I will make out of a 1/2 inch fillport by cutting of the tip.
I will seal the loop with a g1/4 plug.
Here's a picture without the connection piece as I haven't cut up the fillport
