1 - 7 of 7 Posts
I'm building a system for a friend with a very tight budget.
I need a Case/PSU/DVD Burner and a hard drive for ~100 any suggestions are welcome. $120 shipped is the maximum I can go.
I already have RAM, CPU, and motherboard and a HD4830, that the PSU needs to run.
On another note, what is the best price/performance DDR3 RAM?
Preferribly 2GB sticks.
Thanks!
Edit: If it's possible the case + PSU may have blue lighting + case window?
I know it's alot to ask, but might as well try
well you can get an antec 500w for about $50. maybe less. he does not need a case in my opinion. just toss it on some wood or something.
then you want to look around in the for sale section and see if you can find a deal on a HDD and a GPU. I saw a 8400gts in there for 25 bucks. and I bet you could find a HDD for about 30. However your gonna have to pay for shipping so start collecting cans and bottles or something lol
EDIT: also go and look at the recycling center for drives and stuff... I just found an 80gig HDD and a cdr burner today while taking back recycling
Reactions: Slipp
I would put it on a box, but he's not very computer literate and the PC will probably be moving around alot. So, unfortunately going case-less is not an option
Thanks for the reply though, appreciate it.
Edit: Thanks for the newegg links, I've had good experiences with most of those companies so those are definately an option. Might have to cut costs on the case and find a cheap HD though.
1 - 7 of 7 Posts
