AMD for this setup is better then Intel because AMD has 3 cores and have the ability to unlock a 4th core to make it a quad core and it does better in testing then the 7400
I also get the feeling that this will stay stock, as in no overclocking. The stock HSF is more than adequate for stock speeds, which are nice and fast. |
Originally Posted by -Muggz- ![]() Go AMD, and not a bad choice on getting the 790gx chipset, but more so if you are adding a GPU or intend on XFire in the future. Im assuming you are just going to use the onboard graphics, but in that case I might look at a board with an NVidia chipset rather than Ati. I find the onboard graphics from NVidia do a better job lb. for lb than the ATI's. I have experience with both, and IMO the NVidia does perform better for onboard. You can get a real nice NVidia 8300 onboard gpu motherboard for less than $100. Something like this http://www.newegg.com/Product/Produc...82E16813131354 paired with this http://www.newegg.com/Product/Produc...82E16819103291 would be an excellent system and last for several years and perform very well. It also should be noted I usually lean towards AMD/ATI when building, so its hard for me to audibly promote NVidia. |
